400M Engine Masters Winner - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-07-2010, 08:31 PM
I think it means .500" thick- to allow for thermal distortion.
  #17 (permalink)
Old 09-08-2010, 06:08 AM
Go to google and type in Engine Masters Challenge teardown. The 460 based motor that KAASE ran for nearly 3 years ran a 1/2 thick head gasket to accomodate the stroke set up. they were also a small runner, high velocity head with 27 cc combustion chambers with a dish piston. I'll post the link later, and get verification on the extreme low tention ring.
  #18 (permalink)
Old 09-08-2010, 07:49 AM
.500 is 1/2 inch. http://www.popularhotrodding.com/eng...emc/index.html
http://speedtalk.com/forum/viewtopic...96dab&start=15
  #19 (permalink)
Old 09-08-2010, 08:18 AM
I never found the .500" head gasket. It was probably a plate used to raise the deck with sleeves installed through it- not that uncommon.
  #20 (permalink)
Old 09-08-2010, 09:21 AM
"Jon Kaase is no stranger to the world of ultra high performance engine building and the incredibly slick Ford 408 Cleveland he brought this year was by far the most exotic mill in attendance. With its Australian CH1 Cleveland heads, AMC six-cylinder main bearings and .5-inch thick copper head spacers, it was number one qualifier with peak readings of 698.2 hp, 619.6 lb.-ft, average power readings of 485.9 hp and 557.3 lb.-ft. and a staggering 1,043.2 points."
copper Spacers no sleeves...... That was this year, I sent you to the wrong article. Sorry... The ring land is moved WAY down the piston... again not a stock shelf piston or ring. The head gasket/copper spacer was used to accomodate the HUGE 4.2 stroke, since long rod small bore applications are know for withstanding detonation. This along him to run a huge CI motor with a small bore and large stroke... they have to run on pump gas.
Like Ive said these are not simple head, cam, intake deseigns with off the shelf stuff. Withought getting into the math he used a high velocity intake head runner deseign to accomodate the huge stroke... the amount of air needed to fill the cyl in these motors is beyond incredible. They use bores and larger bore cams to increase their centerline angle, and extreme aggressive ramps. The rocker arm ratios get up in to the 2.3 ranges.... There is nothing simple of streetable about these motors for real world applications. Everything is taken to the edge of light, lessfriction, rotating mass, lift, and velocity.
Thank you guys for having a decsent converstion with me... I have missed that.
  #21 (permalink)
Old 09-08-2010, 09:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The engine he ran was about 400 cid.
From Post #2:
  • A "short" 5.965" rod length, w/a 2.350-inch compression height piston that used a low-drag ring package of .043"/.032" compression rings and a 3mm oil ring.
If the stroke is correctly said to be 4.2", that gives a rod/stroke ratio of 1.42. That would also put the bore at <4", somewhere close to 3.9" or so.
I will readily agree that these winning (or placing/showing) engines are not "run of the mill" (ha-ha).
  #22 (permalink)
Old 09-08-2010, 09:38 AM
I wonder why he chose copper... That is a unique piston.
  #23 (permalink)
Old 09-08-2010, 09:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well, it would be a breeze to machine. It would seem at first blush that there'd be issue w/thermal expansion and thus sealing, but who knows what goes on w/him.
The cam was about to take a dump (2.2:1 ratio rockers and all) so the idea of longevity of this engine wasn't a priority- perhaps the copper lasts long enough to get the required pulls before going terminal.
  #24 (permalink)
Old 09-08-2010, 10:12 AM
Thats what I would think as well. They only plan to build to the amount of use...LOL.. The stroke may be off as well, I was just going by the tear down article.
Donnie
  #25 (permalink)
Old 09-08-2010, 10:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Donnie
I'm not doubting you on the stroke, Don- it just goes to illustrate that this whole "long rod good/short rod bad" theory has a LOT more to it than meets the eye.
Drag race/max output engines use less rod length than many guys realize, I believe. Endurance engines maybe less so. The exact engine requirements will possibly favor one over the other- but there's no "magic bullet" to be found in rod length, IMO.
  #26 (permalink)
Old 09-08-2010, 10:31 AM
Rods, are like carbs. Any rod can work, but some work a little better depending on the application. Sometimes smaller has a slight advantage sometimes bigger. Understanding why is something very few people get.
  #27 (permalink)
Old 09-08-2010, 10:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My position is this:
IF you are in that 1/10 of one percent of builders that are needing everything available that can be had- and that's STILL not enough- look for that small edge w/rod ratio (and everything else possible, as well).
For the other 99.9%- whose engine will never see a dyno, and whose tune is 85%-90% AT BEST- rod length/ratio means nada.
Only until the fuel/air ratio is spot on, the timing curve and total timing is optimized, that ALL the other variables have been recognized and taken into account will a rod length other than what is readily available (i.e. 5.7" or 6" for a SBC) be worth anything, output-wise. The change in output wouldn't even be measureable
Because a 6" rod engine can be built for about the same coin as a 5.7" engine, I can say, "Why not?". But if it cost even a small percentage more, I would recommend against it unless there was a lot more to the build and tune than the average Joe.
The only exception to this is w/a 3-3/4" stroke SBC- they should get at least a 5.7" rod instead of the OEM 5.565" rod.
  #28 (permalink)
Old 09-08-2010, 11:09 AM
I just think if you have to buy some rods, the cost between the 3 common lengths is negligible, hell even the cost to run 6.125 or 6.25" rods can be negligible in some cases, so know how the length affects your combo and pick the best one.
If you don't need rods run what you have, people do that on many other items that have a larger effect than rods (reusing carbs, intakes, pistons, even cams).
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
Engine Master's Challenge SBF cylinder heads 2wld4u Engine 5 06-16-2005 10:28 PM
