I have actually been running it a little bit with a cheapy mild cam Melling 22200 and stock heads casting number is 3998997 i believe, cut for 2.02's.
It cools pretty decent till it gets over a 100F outside then it gets a little close to 210 in traffic. I'd like to get some suggestions for a cam and heads for this thing... |
the cam i have in it now specs off the cam card are as follows
cam lift: I .298 E .298 valve lift with 1.5's : .447 Lobe ctr: I 110 E 118 sae dur: 291 .050 dur: 223 .050 events: BTC: 1 ABC: 42 BBC: 49 ATC: -6 doenst lope at idle and has a lot of tourqe and not so much top end |
I recommend you get a copy of "Hot Rod (magazine) Engines" issue Fall 2006, a special issue on the newstands NOW until end of February. A special HotRod do-it-yourself-series magazine.
On page 20 is a story "500 hp For Cheap". A Joe Sherman built pump gas 383 with single plane intake, RHS IRON heads. This might be more radical than you want though. ****************************** If you want something more street livable, I suggest your taking some of the money and maybe up the cam....... use EngineQuest Vortec iron heads that flow 230/160 @ .500 lift, Edelbrock dual plane Air Gap intake, and step up the cam to about a 230* single pattern cam on a 108 LSA with as much lift as you can find, even 1.6 rocker arms, and get into the .550 lift area. Here's an example= Popular Hot Rodding magazine did a Steve Dulcich buildup called "Budget Sledgehammer" on an iron head, dual plane intake, 350 Vortec that did 447 hp for $ 3500. It appears RIGHT NOW on the stands as an attachment to their current issue in plastic wrap. This identical set up with the same cam on a 383 or 400 will make gut-busting 400 lbft torque at 2500 rpm with peak of 480, and with hp in the high 480+ range, run power brakes, and put a smile on your face that won't wipe off for months. That is what I would do. You could always add 12* more cam from a 355 to a 406, and step up from the Vortec 180s to 200s or 220s for a little more money. http://www.eqcylinderheads.com/flow.html http://www.chevyhiperformance.com/te.../photo_14.html corrected link Last edited by xntrik; 01-18-2007 at 11:13 PM. |
Just examples of proven combos. You need to tighten your lobe centers about 4-6* for better power. Contrary to popular belief, lobe center is more important than duration. |
both links i seen were same link..and all the heads i seen numbers for there were for 64cc heads.
Will that not put my compression to high for 93 octane gas? in a .030 400 small chevy with flat tops ...<<This i already have |
corrected link http://www.chevyhiperformance.com/te.../photo_14.html |
compression calculator |
I would look around for a set of aluminum heads,maybe some Dart 200cc heads.I think they also come with a 72cc combustion chamber.Im not sure though.
And maybe a cam: Isky adv. dur. :280/280 dur.@.050:232/232 Lift:.485/.485 LSA:108 http://shop.enginekits.com/osb/itemdetails.cfm?ID=253 |
| Supercharging my 400sbc | 92z28400sbc | Engine | 4 | 05-12-2006 06:31 AM |
| timing for a 400sbc | slewfoot | Engine | 1 | 09-13-2005 09:02 AM |
| How much more HP w/5.7 rod on 400SBC | shockers69 | Engine | 6 | 03-04-2005 10:23 PM |
| rod to cam clearance on 400sbc | 406chevelle | Engine | 8 | 12-07-2003 06:25 PM |
| 400sbc build-up suggestions | Chevymetal | Engine | 7 | 10-18-2003 09:02 AM |
