400sbc flywheel balancing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 06:23 AM
I have a 400 sbc that will be running shortly. The plan is to put it in a tractor for pulling. I would like to use the tractor flywheel, but the 400 is externally balanced I've heard. How much damage will it do running with an unbalanced flywheel or how hard would it be to balance the tractor flywheel
Old 05-03-2012, 06:39 AM
BOBCRMAN@aol.com's Avatar
Send the 400 and the tractor wheels to a balance shop and have it done. A simple job.
Old 05-03-2012, 06:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm curious why the tractor flywheel is wanted- does it have some sort of "special" pressure plate, or is it extra heavy, or ?
Old 05-03-2012, 07:51 PM
There are a number of reasons for the tractor flywheel. 1) the pto shaft goes directly into splines in the flywheel, I need the pto to run a loader that is on the tractor. 2) the friction disc is a different size and has different splines. 3) I think the chevy pressure plate is too small to fit over the input shaft. 4) The tractor flywheel is bigger and heavier. I think I will have to use the tractor starter because there isn't room in the frame for the gm starter. Sorry for the long reply
Old 05-03-2012, 09:07 PM
New Member
all you have to do is take both flywheels to a machine shop for zero out the balance you need then match your other flywheel to that balance super simple!
However, if you try to use an unbalanced flywheel kiss those bearings goodbye as well as that motor.
Old 05-04-2012, 08:21 PM
how do you tell the difference between a balances 400 flywheel and a 350 flywheel. cause I'm pretty sure I only have a 350 flywheel
Flywheel Swap / Engine balancing HP52TA Engine 8 04-10-2009 05:18 PM
Flywheel Balancing bigalow Engine 9 04-21-2008 05:58 PM
Flywheel Balancing Act corvette Transmission - Rearend 1 01-29-2006 08:48 PM
Back to 400sbc balancing! al37ford Engine 6 06-12-2004 03:42 PM
Flywheel balancing? nomis30 Engine 3 11-25-2003 11:03 PM
