400sbc Ignition problem/possible dead short! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2010, 11:13 AM
Just finished building a 400 sbc for my 84 GMC 1500 2wd. I put about 6500 into it and want to get it running so bad I can taste it! Heres my problem:
Installed a new starter and attached jumper cables as my battery has sat for about 6 months; the battery is both side and top mounts which I currently use side mounts. I noticed the cables were arching between the posts when I attached them specifically the negative terminal.
I needed to build oil pressure so I unhooked the green and purple wires coming from my MSD ignition box to the distributor. No spark no start. Got oil pressure, got fuel in the lines, all right lets fire it up. I hooked the green and purple wire connectors back together, cranked it over and it fired immediately but died after a few seconds.
At the same time I noticed a ground coming from the negative battery terminal to the radiator core support was smoking! I replaced it and cranked it and the wire burned up again. I replaced the wire with a huge gauge wire directly from the negative terminal to the chassis. No burned wire but now I am getting no spark from the distributor!
I have an electric fan, disconnected it last night to eliminate it from the problem and still no spark. I was told by a friend that this typically means I have a dead short or a bad ground. Does anyone have any advice? I would greatly appreciate your help as firing this engine up will be a long awaited dream come true.
Old 09-24-2010, 02:18 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Make sure you have 12 volts going to the distributor MSD box even if it means connecting a jumper from the battery + terminal to the distributor power terminal.
Or GOOGLE --- Testing you MSD ignition.
vicrod
Old 09-24-2010, 03:12 PM
35terraplane's Avatar
That is not a very good place to ground it. Get the ground wire on the frame.
Also when you run the wires for good Ground the motor at the motor don't do like some do and ground it from the transmission, Alum. makes for a very poor conductor. Get the ground on steel to frame, Starter bolt, front of engine to frame. You will have far less troubles with the juice.
Later 35terraplane
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
what the .........dead short wierdness tbelltim Electrical 1 10-16-2007 08:06 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
Help wiht my dead Chrysler electronic ignition willys36@aol.com Electrical 12 07-27-2003 10:02 PM
(86 pontiac firebird) hit a dead end in finding short 86Firebird Electrical 2 06-11-2003 11:31 AM
