Hi, I recently got a hold of a 400 that needed to be rebuilt, The engine is going back farily stock, Next Monday its going to be sent in for a Acid Bath and a bore, Im saving up for The Balanced Rotating Assembly, Once I get the money for it, and a Holley Double pumper, Those will be the only Aftermarket parts put into it when I rebuild it, maybe a small cam to.
Would this setup put me around 450hp ? Im actuallly trying to hit 500hp, Im sure this will get close, But I was hoping someone could Run a desktop Dyno.
To start things Off,
406 Sbc, (.03 over)
A 750 cfm Holley Double pumper with a 2 corner Idle system
A Weiand Team G Intake Manifold (3000-8500)
A Summit Hydraulc Flat tappet Lift. .555/.555 Dur @.5inch .260/.260
Dart Iron Heads with a 64 Chamber, 2.08 valves and a 5 angle Valve Job, 230cc Intake, 75cc Exhaust
Shortie Headers with 1 5/8 primaries
Flat top pistons
A Eagle Balanced (external) Rotating Assembly, with forged Rods, Hypereutectic Pistons, and a Cast steel 3.75 stroke Crank
1.7 Roller Rockers
A capacitive Disharge Box, with a rev limiter set at 6000Rpm, ( does tthe Summit Capaicitve Dishcarge Ignition box go to a HEI) ?
Thanks
406 Sbc, (.03 over)
Flat top pistons
1.7 Roller Rockers
Thanks
