400sbc want idle in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2010, 11:19 PM
I have a 1994 S10 with a 400sbc in it and when you put it in gear it will die. unless I keep my foot on the throtlle. the engine is a1975 400 out of a blazer that I have had bored 30 over. It still has the stock heads on it but they have been shaved 20 thousand. It has a performer intake with a 750 holly 3310 carb. a msd distibator and a 3800 stall. I have checked for vacuum leaks and found none now I.m stuck please help.
Old 07-23-2010, 11:31 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I would check the idle mixture screws on the carb. What are the specs on the cam? Should be pretty big for that converter.
Old 07-24-2010, 01:43 AM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...lead,_internal
Old 07-24-2010, 08:00 AM
if you're running vacuum advance it's possible that you dont have enough vacuum in gear at idle to pull it open. try disconnecting it and set your idle accordingly
Old 07-24-2010, 09:25 AM
if you are running a cam that requires a 3800 stall then you need at least 25 degrees of ignition timing at idle.
Old 07-24-2010, 02:18 PM
400sbc idel problem in gear
I am running vacuum advance and have thought about changing to a differant set up. Like maybe a Mallery unalite and a spark box and get rid of the vacuum advance. Thanks for all the tips
Old 07-24-2010, 02:28 PM
msd distributor should be adjustable. set initial timing to 25 and total to 37 degrees (12 crank degrees or 6 distributor degrees).
what size cam?
how much compression?
how much timing are you using now?
The Performer intake is not a high rpm intake. The Performer RPM is not bad but the regular performer is done by 5500.
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 07:03 PM
Idle problem sic72 Engine 2 07-06-2007 11:33 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 12:49 PM
