Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400witha 144
Thread: 400witha 144
Old 09-26-2012, 07:40 PM
sapsz28 sapsz28 is offline
400witha 144
hello fellow hotrodders I\m thinking to change my set up with the addition of a weiand 144 on my 406 sbc. Im going to pull the motor this winter and change my pistons,forged again to get 8:1 compression port my 72cc rhs heads keep my scat forged I beam rods 7/16 cap screws and the stock crank which has been cross drilled and chamfered, the whole unit will be rebalanced due to the new pistons change the power valve to a boost referenced one on my hp 750 holley re jet it, the cam I was thinking to put in is a hydraulic roller 233/241@50 530 int 545ex 114lsa 110 lca would that combo work I already have a roller set up, I have a 110 GPH mechanical fuel pump its a rpm edelbrock said to be good for 600hp which I know is not feasable am I on the right track.I\ve always wanted a blower after going for ride in 1980 vette with a 355 and a 144 on it ,i cant get it out of my head. it was what convinced me to go this route. Any thoughts would be greatly appreciated.
