401 Magnum - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 10:53 PM
Captain Obvious
401 Magnum
alright i'm just seeing what some opinions are on using a 401 magnum motor. to throw into a pulling truck. I know there are probably some better choices but do you think it'd be capable of doing well?
Mind you this is a Big Block V6 made by gmc.
Thanks for your opinions
Old 04-11-2012, 12:47 AM
GMC made some awesome V6s. One of the things I liked about them, and I don't know if it's an actual real-world advantage but I thought it was cool, is that they ran the spark plug wires down the inside of the head.
I ask in all innocence what's it's take to power a winning pulling truck. If low rev industrial strength grunt is needed, you may be on to something. I could be wrong, but a 400 cube V6 has got to have a rotating assembly that weighs something like Rhode Island.
I don't believe anyone makes the parts that will hold the thing together if you have to spin it fast to win truck pulls. You can now school me on truck pulls; low end grunt or high end ponies?
Old 04-11-2012, 12:54 AM
I'm working from memory, but I don't recall GMC calling the 401 a magnum. They produced other V6 engines like the 351 that where both non-magnums (351) and magnums (351M) but didn't the 401 just come out as the magnum?
Old 04-11-2012, 02:47 AM
I intended to say I believe the 401 was just the 401. Other GMC engines were called magnums.
Old 04-11-2012, 10:25 AM
I remember a GMC V12 (2 6ers together) industrial engine a friend of mines dad had in a barn. I wanted it badly, no idea what the heck for. It probably weighs as much as a medium sized elephant.
Old 04-11-2012, 12:11 PM
GMC 702. It wasn't really two sixes. It had a single block and crank. And you're right; you need an engine stand that can support an elephant if you want to rebuild one of these things.
GMC looked at the parts in the bin after putting together a lot of 351s and decided to go for it. Valves and cylinder heads and the like. I'm not an engineer, but I don't see how bolting together two sixes would produce something that could hold up under the stresses it would likely see.
401 nailhead tgreen Engine 14 02-13-2012 09:19 AM
Buick 401 Value? xxllmm4 Hotrodding Basics 9 10-23-2008 04:13 PM
401 amc denny1977 Engine 1 01-21-2006 07:19 PM
Ford 401 velocity101 Engine 5 07-17-2005 02:18 AM
401 ci Nailhead!!! rezervation_pitbull Engine 3 06-14-2005 01:25 PM
