402 or 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2004, 09:17 PM
402 or 454
i have 402bb 72model with oval port heads is that motor worth anything im wanting to build a 500 horse motor i also have a buddy who has a 454 with rect heads who would swap even which route is the best to take
Old 08-31-2004, 09:23 PM
z3pr's Avatar
A legend in my own mind
Last journal entry: 78 El Camino
The old saying is "There is no replacement for displacement" I think you'll reach your goal quicker with the 454.
Old 08-31-2004, 09:31 PM
what kind of moneywould it take to reach 500 horses in a 454
Old 08-31-2004, 09:33 PM
reher morrison says "build the biggest motor you can" I guess I agree, unless that is the original motor??
Old 09-04-2004, 09:13 AM
ratlover's Avatar
to get 500 ponies you are going to need more compression, so that requires new pistons and probably rods while you are at it. add cam and lifters, carb and a home porting job and you will be getting warm. I would guess in the $2500-$5000 range depending on how thorough you are in the build. Put it this way you can spend as much as you want on a motor. usually more than you can afford and always twice what you expected on the onset of the project!
Old 09-04-2004, 09:36 AM
BOBCRMAN@aol.com's Avatar
As stated above "Ain't no substitute for cubic inches" even the wives agree!
Old 09-04-2004, 10:43 AM
New Member
If your goal is 500HP, do the swap for the 454, then sell off the original square port heads and build your motor to these specs:
http://www.edelbrock.com/automotive/7161pp.html
I should have added this. The motor will be more responsive in the bottom end with the oval port heads (original or the Edelbrock heads). The Original rectangular port heads a still sought after, so you should be able to get a pretty good price for yours.
I've got plans to build a motor to these specs that will find it's home in a 77 Datusn 280Z with a Tremic T-56 behind it.
Old 09-05-2004, 07:57 PM
we did a 9.5 to 1 454, stock open chamber oval port heads with bigger valves installed, an isky 280 mega hyd. cam, performer manifold and a 750 and it was 490hp on the dyno. stock crank and rods will be fine. i would build a 454 but loose the rectangle heads unless this is a strip motor. you`ll have more lower end torque with the oval ports and the won`t need a ton of work to get the power you want.
just add bigger valves, mild bowl port work and gasket match and a good valve job is all they need to make 500hp. if this is a street car, build it for low end torque with a rpm limit of about 5,500-6,000 and you`ll have fun with it. by the way, torque is what your *** feels when it`s shoved through the seat when you nail the gas. good luck.
