402" BBC, head question
OK guys, another 1st for me. I picked up a '72 C10 402", and I haven't really messed with the BBC stuff. I have always strayed to the "lesser common" of the Ford and Mopar camp, and last 10+ years, been doing a lot of the LSx stuff...but no BBC.
So, this 402" has been punched .030 over, TRW flat tops @ 9.5:1. ARP rod and main bolts. Comp cams 218/224 .500/.500 Oval Port semi open with Manley SS valves, 2.19 on intake. Crane Gold rocker Edelbrock Performer RPM Holley 750 Vac Sec 3310 MSD 6A ign and coil MSD Billet Dist. and wires Hooker Headers Turbo 400 12bolt with 3.73's Truck runs GOOD. I had to pull carb off (had leak off baseplate), but she has been sitting for last 5-6 years in storage. OK, my question: How can I find out what heads I have? If these heads are "lesser" heads, which route should I go, and will any Mark IV head work. I am asking that because I know the 402 bore size is a lot smaller than the 427 and 454. What do I want out of the truck? To have fun.....but you can't ever have enough nuts. Thanks guys. |
And they would be where?
First lets have a look at the id numbers on the pad on the block in front of the passenger head. Then remove the valve covers you will see the head casting numbers. When you find them post them in your thread. The 402 should have a set of closed chambered heads on it. The bad news is even with a set of closed chambered heads and the flat top pistons your compression ratio is around 8.0. A set of KB160 pistons with a .180 dome and a set of 105cc closed chamber heads would bump it up to 9.6.
Well, the heads have been changed out, that I know. The longblock was done @ 10 years ago, by the machine shop I use for all my other stuff.
So, they are NOT the heads the 402 came with, but the shortblock IS original to the truck. Stock crank, stock rods, resized and now house ARP rod bolts. Mains carry ARP studs, and pistons areTRW flattops. WHole rotating assembly has been balanced, new oil pump, TC, etc....Heads have also been ported, but here is the kicker: Only ONE of the heads has been ported. WHat happened was, one of the heads started leaking water from getting a little carried away obviously, so they grabbed another head, threw a valve job on it, and took valvetrain from bad head and placed it on this head. So, I have one ported head, and one not ported, LOL! I was hoping I didn't have to pull the VC off to find the numbers, but figured I would. OK, give me some time here, and I'll let you guys know what I find. Thanks |
OK, here is the deal about that: The shortblock (402) is rather fresh, with only around 15-20K on it. So, I was planning of doing is, pick up a set of "good" BBC heads, plop them on my shortblock, and let it eat for time being. Probaly even going bigger on the cam while I'm doing heads.
Once I had some fun with the truck, locate a shortblock, freshen it up, then take the heads on the 402, and plop them on my new shortblock (probably do a basic 496" shortblock. THAT is why I wanted to know if any BBC head will bolt on my 402, so when I went 454" based shortblock, my heads would work on it. Take for example SBF stuff. You can take a measly 302 Windsor, and place ANY head designed for a 351Windsor on it. Or, take the LSx stuff: You can take a head off a 4.8, 5.3, 5.7, or 6.0 and any head will work on any of those blocks. HOWEVER, you CAN NOT put a 6.2 head (the L92) on the 4.8, 5.3, or 5.7, because the 6.2 head calls for mininum bore size of 4.00". So, since I know my 402 bore size is quite a bit smaller bore size than the 454, I wanted to know if the heads interchange, OR if I would run into a problem with valves being way to close, or hitting the cylinder walls. See what I am saying? |
OK, here are the numbers I pulled from under valve cover:
the 7 digit number: 3931063 I had a hard time reading that 2nd 3, and the last 3, so it might be the following instead: 3981068 Or 3931068 Or 3981063 I also found: GM4T and PA3S (drivers head says PASS, so maybe that 3 is actually an S??? I already put PS VC back on so can't double check it) Hope that helps guys. Those are the numbers on passenger side head. Last edited by Peepaw; 02-08-2013 at 08:08 AM. |
OK, and it appears I may actually have a different head on drivers side all together
![]() The numbers I pulled from drivers side head, under valve cover, are: B87 GM6T PASS Conv4 Those are the only numbers I could find...so no 7 digit number. So, what are we looking at guys? LMAO!!!
OK, my mistake, there IS a 7 digit number...was just kind of hiding from me on the drivers side there:
It's: 3909802 OR 8909802 Hope that helps, thanks |
Oval Port 1969-70 396 Closed Chamber 100.9cc |
From best I can tell, I have one 063 head, and an 802 head. One head ported (don't know which), and Im not pulling intake off at this point, but both heads have a valve job, and oversized intake valves. From what I gathered, the 063 seems to be a pretty decent head, and the 802 is rather similar, but maybe not as in high regard as the 063??? I found a few threads with guys making pretty good power in 396-468" cube motors with the 063, but not so many with the 802. Granted I didn't do a whole lot of searching, but that is what I have come up with so far. Any tips/suggestions guys? |
What I want is more power of course but my question is: the heads I have....worth a crap? If so then what can I expect out of them on top of a 496" shortblock? Or...r there better stock head options out there that I can boot on the 402" and once the 496" is done plop them on it? On motor...would be nice to tickle 500+....whatstock heads can carry me there
| 402 BBC | rfb92345 | Engine | 2 | 12-02-2008 12:53 PM |
| Bbc Head Question...which One Do I Get?????? | 76 elco | Engine | 5 | 10-17-2008 11:10 PM |
| Question about BBC (396) head | heyjude076 | Engine | 5 | 03-13-2008 09:39 AM |
| BBC Head Question | maddogg20 | Engine | 14 | 01-09-2008 09:25 AM |
| BBC cylinder head question | Ratoflic | Engine | 19 | 11-14-2005 03:22 PM |
