402 bbc piston orientation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 08:11 PM
Hi everyone.I bought a 402 bbc in pieces.This my first bbc build.My question is,which way does the dimple point?Does it go to the intake side or the exhaust side?Thank you for your help and consideration in advance.It is much appreciated.
Old 11-27-2012, 09:32 PM
Scoll to the second page and look for big block chevy and ford. The easy is way to remember is the intake valve is on the right-hand side of the piston looking down at the piston from either side.
Old 11-28-2012, 10:29 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
most of the time the dimple always points forward.
Old 11-28-2012, 07:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some pop ups have a divot or groove for the plug, so I'm wondering if he's talking about that, or the front orientation dimple like you just said, or if maybe he's talking about the dome itself?
Anyway, as said before, the intake valve relief goes to the right as you look at the block from the side. Also if the pistons are on the rods the right way, the bearing tangs will be towards the pan rail. At the big end of the rod, the large chamfers goes towards the crank cheek.
Old 11-28-2012, 08:21 PM
402 piston orientation
Just wanted to thank you guys for your info.Cobalt told me what I needed to know.The dimple I was talking about is to the left of the valve relief,near the edge of the piston.Thanks again.
Old 11-28-2012, 08:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are your domes pretty big, then? I'm curious now about what kind of beast you're building...
Old 11-29-2012, 09:19 AM
402 piston
No they are stock. Im keeping it mild because of a small budget.Its going in a 70 c-10 im in the middle of restoring.After im done with this I have 64 short bed stepside im going to build to death.I have a 2000 5.3 i want to build and possibly supercharge to go in it.
Piston ring orientation zz71s Engine 3 03-25-2010 11:42 PM
Bearing Marks and Piston Ring Orientation! airjose Engine 1 10-10-2009 09:47 AM
BBC 402 cam help ?????? 198plus Engine 3 12-14-2008 08:00 AM
402 BBC rfb92345 Engine 2 12-02-2008 01:53 PM
BBC 402...on a budget boatanchors Engine 5 11-24-2008 06:46 AM
