Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-30-2008, 02:08 PM
65chevypickupguy 65chevypickupguy is offline
402 GMC motor
I have a 65 chevy pickup with a 350. I have always wanted to install a BBC. I found a '70 GMC 402. I heard it's just an overbored 396. Are there any problems rebulding these motors? Specifically overboring it. Also, has anyone stuffed a BBC into a 65 pickup. Will the frame mounts for the motor fit the BBC?
Old 11-30-2008, 03:47 PM
boatanchors boatanchors is offline
this hobby is expensive!
re: 402 GMC motor
i have a 62 chevy pickup set up for a big block...the only problem i had was the torsion bars are in the way of headers and i had to make motor mounts because the original 283 had that stupid horse shoe mount in the front. i just tossed the body onto a 63-66 frame. i took the motor mounts off an 85 chevy truck (V8) and put some 70 chevelle 454 mounts on top of the 85 truck mounts and the motor bolted right in. you can pick up any of these mounts at autozone (not exactly my favorite store) the have them behind the counter pretty cheap. and as for the 402 i think its a decent BBC i am putting one together now and my dads had one in his chevelle 0.030 (makes a 408) since 1983. never had a problem with it so far. also my truck is from california so it was heat delete from factory. if you have that boxy heater its going to be a tough fit for a BBC. its a huge truck but peaple dont realize the fender wells are huge and the frame rails are 28" apart. so believe it or not a big block is a tight fit, but it is worth it. i wish i had some pictures to show how we did the mounts and stuff
Old 11-30-2008, 10:12 PM
402 GMC motor
boatanchors, The 85 chevy pickup mounts you refered to, are those pieces between the frame and the motor mount?
Old 12-01-2008, 12:32 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
 curtis73's barnstar
Wiki Edits: 13
re: 402 GMC motor
It is an overbored 396, but it should be fine for at least another .030", maybe more.
While you're looking for engines, 454s are cheap. If you're going to spend money on a 402 which is just slightly bigger than a small block, why not look into the 454. Its probably no more expensive, but its 50 more cubes, which means more torque for the same HP.
Old 12-01-2008, 03:40 PM
re: 402 GMC motor
yes on the fran to the front end then the mounts welded to it. i could only find a picture of exactly what i did on ebay so heres the link hope it helps
http://cgi.ebay.com/ebaymotors/1973... Q5fAccessories
sorry it would not let me just save the pic to my computer then post it on here.
Old 12-01-2008, 03:42 PM
re: 402 GMC motor
o and im almost positive 73-87 has the same mount setup for all the years
Old 12-01-2008, 09:57 PM
198plus 198plus is offline
re: 402 GMC motor
Here's some information on big block swap.
http://www.chevytalk.org/fusionbb/s...php?tid/197202/
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "402 GMC motor"
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 7 10-29-2008 07:07 PM
AR RACING 383 Motor 64Duece Engine 24 10-01-2008 08:59 PM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
383 stroker motor George Hendricks Engine 15 10-14-2006 10:15 AM
Putting a Grand National Motor in a Cutlass ChrisMiddleron Engine 5 01-10-2006 11:53 PM
