402 rebuild or crate motor - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-18-2004, 04:18 PM
Red face 402 rebuild or crate motor
Hello This is my first time on Hotrodder
I have a 68 chevelle I am building.
402 bbc
TCI full comp. th400
12 bolt posi - 4.10's
The suspension is done: agr quick ratio steering, global west tubual a-arms,
QA-1 coil over in front, hotchkis sway bars and hotchkis rear suspension.
Thank You
Rob68427
Old 12-18-2004, 05:48 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome to the board. Since you are new here, I suggest you read the "Read Me" threads at the top of many of the forums to see how they are set up. For example, this forum is intended for "Howdy" introductions only. Tech questions should not be posted here, rather they should be posted in the appropriate Tech forum ("Engine" in this case) so they will ge the best exposure to the experts.
Old 12-18-2004, 08:42 PM
Thank you Willy's
