Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 403 olds again
Thread: 403 olds again
  #18 (permalink)
Old 05-13-2012, 05:49 AM
Mr. P-Body Mr. P-Body is offline
Another misconception. In truth, it's easier to get a "stock" timing set "lined up" using a straight-edge through the bolt hole "centers", across the "dots" while at 12 o'clock. This reduces the potential for 'missing' the timing by adding a longer distance to check that the dots are truly "lined up". Of course, degreeing the cam is the REAL way to do it "right". Gimme a break guys, I've only done this a few thousand times... (:-
Jim
