403 olds big block versus 350 target master rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2009, 11:01 AM
403 olds versus 350 target master rebuild
i was just told this is not a big block so sorry about the title guys. i have a 403 olds motor that has been prevously bored .30 over by the person that had it before me. it came out of a 85 olds cutlas, the origional origin of the motor is unknown. the whole engine appears to be in good condition, except the crank. it has grooves spun into it. i will have to replace it. the rest was in good shape when i put it back together to keep rust out. the 350 runs but has some problems and will need to be over hauled if not rebuild. it will be in a 79 trans am. my question is, by each of your own experiences or oppinions which motor will be better for the time money and power that will come from the motor rebuild for my car. i have a th 350 tranny for the 350 and it is allready in the car. i will have to get a tranny for the big block. it has the stock gm 10 bolt posi rear end and the car orrigionally came with a 403 to start with. any help or comments are appriciated.
Old 08-12-2009, 11:58 AM
Originally Posted by dustin.campbell3
i have a 403 big block olds motor
No, you don't. The 403 uses the same short deck height and crank as every other SMALL BLOCK Olds motor. The big block Olds motors have a taller deck to accommodate the longer stroke of those motors. If you buy an aftermarket intake for your 403, it will be a small block Olds intake.
Sorry, but I'm still not clear. Is the the trans currently in the car a Chevy bolt pattern, a BOP bolt pattern, or a unisex case?
Old 08-12-2009, 12:06 PM
(Sorry, but I'm still not clear. Is the the trans currently in the car a Chevy bolt pattern, a BOP bolt pattern, or a unisex case?)
the tranny is currently in the trans am. it is a gm 350 turbo. i only has one set of bolt boles and bolts to the 350 motor. works and runs fine.
Old 08-12-2009, 12:13 PM
You would need a different trans then, if you went with the chevy.
But, for the cost difference, you might be better off with the chevy, as far as performance parts go at least.
I've always had a fondness for oldsmobiles though, so I'd recommend keeping that, as long as the main journals are still good, and only the crank needs replacing.
Olds can make plenty of power, and don't have that belly button factor.
Old 08-12-2009, 12:17 PM
GM made three different TH350 cases and four different 350 motors with two different bolt patterns on the back of the block. Is it a Chevy 350, Olds 350, Buick 350, or Pontiac 350?
Old 08-12-2009, 12:26 PM
"403 olds versus 350 target master rebuild "
it is target master is a gm motor. it came out of a 77 chevy truck that had a swap to a crate target master. so im gonna guess its a chevy, im not too educated on targetmaster.
Old 08-12-2009, 12:58 PM
He's right. Keep the Chevy. I'll take that worthless 403 off your hands.
Old 08-12-2009, 01:06 PM
personally i dont think the 403 is worthless cause it is the origional motor for the ta but i dont know which one would be better for the money and power
Old 08-12-2009, 01:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That you are open to using the 403 in the first place is good, shows that you are willing to see the possibilities in something that's not wearing a bowtie.
That said, by your own criteria of "time money and power", I would also opt for the SBC engine/TH350 combo. But hang on to the 403- as you grow more knowledgeable in the sport, you may want to do something w/that 403 before you're done.
Old 08-12-2009, 01:20 PM
I was being more than a little sarcastic, given the prevalent attitude that Chevy motors are so much less expensive to build than other GM brands. Seriously, I'm always looking for 403s for sale.
Old 08-12-2009, 01:21 PM
So where's the original TH350 that came with that 403?
Old 08-12-2009, 01:30 PM
i got the 403 through a trade about a year ago. i traded an old beat up 89 chevy truck for a 308 rifle and the 403 motor, there was no tranny for it cause he wanted to keep it for the car he had. the guy that had it before me had the crank ground down after the first rebuild and didnt blow out the journals and the crank ended up gettin grooves in the main bearings and now it is to far gone to have reground so im gonna have to get a new one.
Old 08-13-2009, 01:45 PM
fast68's Avatar
likes chevy trucks & boobies
i love the 403 olds engines they run really strong in the lower rpm and pull hard i miss the one i had in my 77 electra low miles
it was a runner
also the 425 in the 79 deville limo i had as well
good engines
rare now here
finally got to see anopther 403 recently running really good in a 79 t/a out here we had for a bit
rest are all demo derbied gone
the 40s was in the late 70s trans ams, electras, and such
top of the tran case on the chevy and dual pattern cases are pointed up
BOP and caddy only are curved downwards at the top of the case
where the bolt pattern is
dual pattern multifit cases are 10 bolt housings
i have a TH350-C this way right now frm an '81 c-10 pickup with 350 olds diesel
original
it fits all 90 degree pattern engines from gm including the little v-6 such as the 200 chevy
3.8 229 chevy
3.8 231 buick
and the 4.3 chevy
also the old 1960s gmc v-6 truck engines like the 305 and 351 and 478 etc.
Old 08-13-2009, 06:12 PM
go 40....3!
50 plus cubic inches is a big advantage, if you don't plan on revving past 5500rpm, the olds will make more torque on a budget!
Old 08-13-2009, 10:52 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Since we're talking about an engine to go in a TA, why not think about a stroker 400 (stronger than a 455). Same bell housing bolt pattern as an Olds, and the starters are interchangable. I know that Pontiac came out with an Olds powered TA, (corprate politics) but I think a Pontiac should have a Pontiac engine, an Olds should have an Olds, and a Chevy should have a Chevy.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
olds 350 heads for 403? 403_CHEVY Engine 3 08-27-2009 01:19 PM
Target Master MEXICAN BLOCK Soto SS Engine 3 08-21-2005 12:04 AM
Is the Pontiac 350 considered a big block? PD69 Engine 9 07-23-2003 11:00 AM
Horsepower on the Target Master 350 chevylovingfarmboy Engine 1 03-06-2003 01:31 PM
