406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2007, 08:38 PM
im going to build a 406 this winter i race every weekend im going with a forged piston will the stock rods be ok if not does the block have to be notched for 5.7 rods
Old 09-21-2007, 11:05 PM
DoubleVision's Avatar
The short rods are okay, if they are magnafluxed, shot peened, new rod bolts, and resized. a 5.7 rod is far better, run a small base circle cam and you`ll have more clearence, but you still will have to do a complete mock up and check all the clearences, and remember, heat brings expansion, so is sometimes a good idea to add a few thousanths. We ran the stocker 400 rods with good success and they were just that, stock, but we didn`t rev it over 5500 and I think we got lucky. It`s better to use the longer rod due to the added rod ratio, the short rod is so short it out runs the flame front on the power stroke at upper rpm.
Old 09-23-2007, 08:58 AM
The 5.7 rods are a better choice they are stronger. You will likely need to cam clearance the rods.However they can be purchased from speedway motors, midwest motorsports etc. for about $10.00 with the clearancing already done the rods resizes magnafluxed and good bolts installed.We run them in dirt track engines all the time at 7200 rpm no problems in a 406.
Old 09-23-2007, 02:36 PM
thanks for the help
list your 400 or 406 sbc combo's here,,, what works the best for you tiresmoke55 Engine 16 08-12-2010 08:26 PM
still having 406 trouble tiresmoke55 Engine 26 11-23-2009 11:58 AM
406 sbc questions tiresmoke55 Engine 13 04-26-2007 10:50 AM
406 build up,,, need to have more HP tiresmoke55 Engine 34 09-01-2006 10:21 PM
timing on a built 406 Blob Engine 8 06-04-2004 07:27 PM
