Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406
Thread: 406
Old 02-09-2013, 12:02 PM
macrobert68's Avatar
macrobert68 macrobert68 is offline
Small Block
Hello everyone ,
This is my first post and could use some info .Problem is my arp studs that I have coated with arp thred sealer durning the build are leaking (only distelled h20 no antifreeze )after start up .I did not see any leaks after first run only 5 min.After second run up to temp around 150 leaks of water out of lower head bolts So i pressure tested it to 10 lbs and almost all leaked .Why WHY WHY
