406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2009, 09:17 AM
is there such a thing as a 406 stroker?
Old 10-01-2009, 10:05 AM
DoubleVision's Avatar
Yeah, they make cranks now with longer strokes than can stretch the cubes up to 421 inches and more. Check this out:
http://www.coasthigh.com/Chevy-400-b...kits-s/136.htm
Old 10-01-2009, 10:16 AM
400 crank
is there a 406 i can build with a 400 block and crank that is still a stroker
Old 10-01-2009, 10:38 AM
Not that I know of, why stroke one to get 6 more cubic inches?
If you bore the block .030 you get a 406 hence where the name came from.
If this is the depth of your knowledge I`d suggest learning far more before
taking on anything else. There are other things you should know about a 400 before attempting to build one or hot rod it.
Old 10-01-2009, 10:46 AM
ok so what would you suggest i do with my 400 to get decent power
Old 10-01-2009, 10:51 AM
As I said, first, learn more. The 400 has shorter rods than any other small block. The 400 is also externally balanced so it uses a specific balancer and flexplate. The main journals are also larger than any other small block as well. The 400 has steam holes in the block and heads and if the heads are replaced and these holes aren`t drilled it`ll do nothing but run hot.
As I mentioned in my other thread, how much money do you have? What kind of car? what rear gears? what transmission? I would suggest moving your questions over to the hot rodding basics forum, that`s where beginners go to learn more. Since 400`s are so scarce, you could likely sell yours for a nice buck and get a 350 and have that much more to invest. Keep in mind engine alone won`t do it, you gotta have gears too.
Old 10-01-2009, 10:56 AM
ok it has 4.10 gears 14 bolt, and a 4 speed munci i would like to spend 500 to 600 dollars
Old 10-01-2009, 11:02 AM
If the engine needs a rebuild, 600 bucks won`t even cover that.
Old 10-01-2009, 11:11 AM
i have all the heads intake and gaskets its board out 30 over my friend has KB 400 pistons with a 5.7 rod would this give me anymore power? and could you suggest a cam for low end
Old 10-01-2009, 12:16 PM
is it possible to to put a 6.00in rod on the 400 crank if so what would it do besides commpression?
Old 10-01-2009, 03:41 PM
lg1969's Avatar
Google "Tunnel Ram 406"
5.7" rods will work fine. Get flat top pistons with -6CC 4 eyebrows. You will 9.4:1 compression using 76CC heads. The stock 400 heads are 76CC chamber. or 10.8:1 compression using 64CC heads. For camshaft use Comp Cam 280H or equiv. Becareful when breaking in a cam. You will need special engine oil during the breaking in period. You should get at least 470 to 480HP @ 6200 RPM with 550 ft lbs of torque. The KB400 piston, are they flat tops? Hope this will help you.
Old 10-01-2009, 05:51 PM
is that how much power you will get from just putting flat top and a longer rod in?
Old 10-01-2009, 06:38 PM
when i was reading more about this 406 i found out that all it is is a 400 block 400 crank board out .030
and a 5.7 rod or a 6.0 rod so why cant i build it out of the original crank
Old 10-01-2009, 07:40 PM
I already said a 406 is a 400 bored .030 over. There is no reason why you can`t use the stock crank. You can use 5.7 rods but you will have to grind the block for clearence or use a small base circle camshaft. The clearences will have to be checked during mock up assembly. As I also said, with the little you know you need to learn more before diving in. It`s not so easy you can just throw it together and make it perform. If you use the 5.7 rods you`ll need the correct compression height pistons. Same goes for 6 inch rods. If you use KB hypers the ring ends will have to be gapped so they don`t butt together because if they do the ball game`s over.
If you want to learn the formula to cubic inches here it is:
Bore X Bore X 0.7854 X Stroke X Number of cylinders.
Have the heads been checked? are the guides still good? You mentioned the block is already .030 over, but what is the current bore clearence? If it`s excessive you`ll have nothing but piston knock and the rings will never seal.
That`s why I keep saying learn more before you dive in or the engine will be junk before you fire it up and you`ll spend more money doing it all over again.
Old 10-05-2009, 05:48 PM
how can i learn more about my 400
well where can i learn more about my 400?
list your 400 or 406 sbc combo's here,,, what works the best for you tiresmoke55 Engine 16 08-12-2010 08:26 PM
still having 406 trouble tiresmoke55 Engine 26 11-23-2009 11:58 AM
406 sbc questions tiresmoke55 Engine 13 04-26-2007 10:50 AM
406 build up,,, need to have more HP tiresmoke55 Engine 34 09-01-2006 10:21 PM
First 406, what to upgrade first?? boatnut Engine 11 10-03-2004 07:38 AM
