406 9:5:1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 09:59 PM
Can 406 sbc get 500 HP with 9:5:1 compression
Old 03-20-2011, 10:10 PM
ericnova72's Avatar
More for Less Racer
Yes, but it takes a really good cylinder head and big cam to do it.
Old 03-21-2011, 08:07 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Awhile back Car Craft magazine wrote an artical of building a 406 with 9.5 compression and got over 500HP with over 500ft lb of torque @ 4500.
I'm not to sure they used. I think Car Craft used AFR 227 Heads with 280H Comp. cam.
Old 03-21-2011, 08:09 PM
406 sbc 9:51
I'm building a 406 sbc . I'm going with pro 1 aluminum heads 200 intake runners and 64cc chambers ,with custom grind cam I'm not sure on the specs ,Srp pistons,egal crank 5.7 H beam rods and a dart air gap intake . I'm hoping to get 500hp out ,do you guys think this is possible ???
Old 03-21-2011, 08:18 PM
i would lean towards 430hp unless you do some serious david vizard/smoky yunick blueprinting, exotic coatings and very loose bearings.
all the stuff that makes a outstanding race engine but hard to drive street car.
so i think 500 can happen it just all depends on how deep your pocket book is and what your going to use the engine for.
Old 03-21-2011, 08:31 PM
What I was looking for was a torque monster ill be on the street more then track . I had a friend tell me that it was impossible to get 500 HP out of a 9:5:1 engine... that's the combo my engine builder gave me so I hope that's what I get
Old 03-21-2011, 09:04 PM
ericnova72's Avatar
More for Less Racer
I'd say your heads aren't big enough, 200cc is on the small side for a big 400. 215-230cc would be a better match.
The 200cc should get you to the 440-460 hp mark unported.
Old 03-22-2011, 07:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If this is a street-bound deal, you'd be better off using the heads you have and build it for more torque lower in the power band than to use so much cam that the CR has to be high, looser stall, steeper gears, etc.
If the cam was chosen correctly, you'll have PLENTY of power for the street using those heads. 500 HP is just a number- do not get caught up in a "numbers game"! Build the engine to suit your needs and to hell w/the actual output- again, you will have plenty of power.
And you can tell your buddy that he's wrong on the 500 HP/9.5:1 CR. Like ericnova72 said- it can be done. You might not like the manners on the street, though.
Old 03-22-2011, 08:47 AM
OLNOLAN's Avatar
Good Cookin
Check out this recipe;http://www.hotrod.com/techarticles/e...ine/index.html
Old 03-22-2011, 11:26 AM
That's a combo I wanted to go by but my engine builder told me that hydraulic roller were heavy so got me to go with a full roller cam . I believe its crower..
Old 03-22-2011, 12:01 PM
psbaker75's Avatar
Popular hotrodding has an article in the may 2011 issue describing a "streetable" 11.4/1 577 HP 407. Might give you some ideas as to which way you could go... of course it was built for the engine masters challenge, so budget will be a big consideration. Still, there are probably plenty of tips/tricks in there which you could apply to your build.
Old 03-22-2011, 12:10 PM
ericnova72's Avatar
More for Less Racer
Posting your actual cam specs would make power guesses a lot more accurate.
You do have the makings of a very good street torque engine, I agree with that. It just won't make your 500 hp target if you have to have that big #. Head porting could get you there but cost another $700+
Old 03-23-2011, 04:31 AM
I'm working on getting those cam specs
Old 03-24-2011, 03:16 PM
My cam is 497 intake and 503 on the exhaust with 268/274 duration
Old 03-24-2011, 03:25 PM
thats quite small for a big inch motor.
would make a great daily driver tho with excellent street manners.
without forced induction you wont meet your 500 goal.
you need something really hairy for 500 na
unless your duration numbers are at .50 but i dont think so with those lift numbers lift should be in the 550-600 in range depending on your rocker geometry
