Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 or ?
Thread: 406 or ?
Old 01-16-2008, 10:21 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Nope, the lenth of the rod has no effect on the stroke depth, only the crank does. When you have the same bore and stroke you have the same cubic inches. You increased the bore size so you picked up about 5 cubic inches, but the lenth of the rod has no effect, the stroke of the crank stays the same regardless of the rod lenth.
