406 balancer& flywheel combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 03:03 AM
A littlle guidance fellas. I have a 406 built short block and balanced,it was balanced with a flexplate and a stocktype looking harmonic balancer.
My dilema is, my car is a 4 speed,what combination of balancer and flywheel do i use,Ive heard my 350 balancer and flywheel combo from my 355 in the car right now can be zero balaced and used,or do I need a new flywheel and balancer combo for a 400, i dont mind spending the money,Just that I only spend it once and done right.
Old 10-19-2010, 07:07 AM
flywheel combo
Please ,guys,any help would be great before I commit,to something I'll rgret or break.
Old 10-19-2010, 07:39 AM
SSedan64's Avatar
Did the 406 Balancer have a portion on rear of outer ring removed or smooth like a 350 Balancer?
If the 400 type HB was used it's externally balanced and will need a 400 external balance HB & external balance Flexplate.
If the HB was smooth like a 350 HB it was Internally balanced & you can a neutral HB & neutral balance Flexplate.
Old 10-19-2010, 08:20 AM
techinspector1's Avatar
Wiki Edits: 326
SSedan64 is saying flexplate. I'm sure he means flywheel. The car is a 4-speed.
Old 10-19-2010, 08:52 AM
SSedan64's Avatar
Ooops, yes
Old 10-19-2010, 04:11 PM
406 balncing
I'll get back to you on the original HB to see if it was smoothed out during its original balancing. Thanks Guys
Old 10-19-2010, 04:53 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
I felt like I missed something or possibly that Sapz28 did. No offence intended
I'm not sure what z28 meant... Where is the HB it was balanced with and why would you consider replacing it? It would not have been modified during the balancing procedure.
Where is the flex-plate/flywheel which was used to balance the assembly? If it's an aftermarket, internal balance crank, then it would have a neutral balancer, which is technically a dampner rather than a balancer, and a flexplate or flywheel which is also neutral in balance. If so, and you did not supply the HB and flywheel, then some shops would use a perfectly neutral flex-plate and dampner which they keep for that purpose. But most shops agree it is best to run it with the parts used to do the balance..
And if it was done with a factory 400 crank (external balance type) and flexplate, then that plate has a weight on it..and factory type balancer wherever it is, is irregular looking.
I would try to contact the guy who did the balance work and ask him whether the crankshaft is external balance or neutral.
Old 11-07-2010, 02:54 AM
406 balancing
I have the dampner and flex plate that the motor was balanced with,it is the small one 6.75,and not sfi rated,as well I need a flywheeel not a flex plate,I want to put a either a professional products 8.00 inch sfi dampner with my fly wheel,or a sfi fluid dampner, and dont no if I need them both externally balanced since the crank is an externally balanced one or get them both neutral balanced,I will contact the machine shop that put it together and do what they reccomend.
Thank you fellas.
Old 11-07-2010, 03:58 AM
ericnova72's Avatar
More for Less Racer
Stay away from Professional Products balancers, there are many problems being reported for them on some of the engine machinist web sites, including video of an SFI rated one coming apart on the dyno after only 40 seconds light use warm -up and then it comes apart in the first steady-state AFR check at 4000 rpm. They are not well thought of around the web.
Fluidampr is not well liked either, it is missapplied technology left over from stationary deisel engines, and some crank companies will refuse to warrantee a crank if it was used with a Fluid filled damper.
PowerBond, BHJ, Pioneer, Pro Race, Cyco, ATI, Innovators West, Romac, and the Summit SFI are all good, ATI and Innovators West are the best.
Go to an 8" if you can, tests have shown the larger they are the better they work and they make the most power and longevity. Small, light units are shown to be not as good, despite being lighter the car goes slower opposite of what a lot of people think. GM knew this when they put large 8" balancers on all their HiPo offerings like the 302/Z28, LT-1, LS6, L88, etc..
406 sbc starter flywheel problem CHEVYBOY89 Engine 4 09-18-2011 09:14 AM
Thoughts on my 406 combo sbb350 Engine 3 07-28-2010 07:14 PM
406 combo, your thoughts 406 ss monte Engine 18 06-15-2008 07:19 PM
chevy 400, 406, 383, etc people list your combo and what you run! Warrant Engine 4 12-07-2006 11:59 AM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
