406 Break in oil additive choice?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2012, 08:46 PM
farmwalker's Avatar
Hey guys, finaly got the pan on and about to prime the egine for it's first start up. I've heard lots of different oils and additives for breaking an engine in. Just wondering what some of your guys' oppinions were on type of oil and what additive to use??
Thanks, Farmwalker
Old 12-08-2012, 09:16 PM
vinniekq2's Avatar
what did you set your bearing clearances,,,? Can you get E.O.S. in your area> from GM?
Old 12-08-2012, 10:37 PM
farmwalker's Avatar
I'll have to go check. It'll be tomorrow before I find what my clearences were. And probably, what's E.O.S.?? Do I get it from a dealer?? Or can I get it from a local auto parts store?
Old 12-08-2012, 10:48 PM
farmwalker's Avatar
Also Lunati recomends using strait 30 weight non-detergent motor oil for initial start up and break in, with there cam I have. Just adding that...
Old 12-08-2012, 11:15 PM
vinniekq2's Avatar
GM sells or used to sell a very good item called S.O.S.
engine oil supplement, I use straight 50w in my engine,mineral oil
Old 12-08-2012, 11:57 PM
Lucas makes an additive, it not only works great for break-in, its designed to run it at all times with FT cams, Its there zink additive. I've been running it in my 406, I broke in 2 Hyd. FT cams & all is good, even broke in the cams with the stand 132/320 spring pressure.
Old 12-09-2012, 05:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks, Farmwalker
There are special oils used for break in (Royal Purple, Joe Gibbs, Comp Cams, etc.) but for a straight 30w you can use Brad Penn 30w break in oil @ ~$6.00/qt (I don't know if there are other straight 30w break in oils or not), or any good 30w HD oil w/an additive like ZDDPlus.
No special additives needed if you have a roller cam.
A couple pages w/some info:
Adjust lifters
Cam break in
First start up
FWIW I have always used a 30w HD single grade oil for break in, not a multi-grade. But it seems that a lot of engines are now broken in using 10w-30, 15w-40, etc. No idea if this has anything to do w/cam failures we all keep hearing about, or not. And yes I know what the numbers mean. Just saying.
Old 12-09-2012, 06:19 AM
ZDDPlus™ - ZDDP for Classic, Muscle Cars & More
Old 12-09-2012, 06:26 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Adjust lifters
Cam break in
First start up
Interesting about the 15W-40. I had read somewhere about Shell Rotella 15W-40 being good and was using that. I used EOS from GM for break in. This was a mild 212/212, .440/.440 cam. I was doing a cam swap and found the lifter just starting to get concave when I held a straight edge across the bottom. I should have been using the additive on every oil change ....or was the 15W-40 the cause?????
Anyways, no more FT cams for me after seeing that.
Old 12-09-2012, 10:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The straight 30w was just for break in. After that I always use a multi-grade.
I tend to err on the cautious side, so I use ZDDPlus at oil changes, even on my DD '80 Malibu w/a flat tappet V6.
Old 12-10-2012, 02:43 PM
I'm getting ready to break in a new cam in a newly rebuilt engine. I bought the Comp Cams break in oil. When using this oil, is it still a good idea to add ZDDPlus for the cam break in? Or is that overkill? I have a supply of the ZDDPlus on hand, which I put in my 86 Grand National with every oil change. Thanks,
Old 12-10-2012, 03:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Too much additive is not good. Use the break in oil as-is. Use the ZDDPlus once you switch to over the counter oil.
Using a moly break in lube on the lobes and bottoms of the lifters (only the bottoms, motor oil for the sides of the lifter) is also important.
Some links that you might get something from: 350 SBC / Vortec Heads: Cam Choice?
Good luck.
Old 12-10-2012, 04:42 PM
farmwalker's Avatar
So where do I get E.O.S.(Engine Oil Suplement from GM)? Do I have to go to a dealer or can I get it at a local auto parts store??
Old 12-10-2012, 04:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I always went to a dealership.
GM Break-in Additive TUFF-55 Engine 13 04-07-2011 08:09 PM
406 Cam Choice HP52TA Engine 1 08-25-2008 08:47 AM
adding break in additive to brad penn? bonzipenguins Engine 5 04-29-2008 09:42 AM
Cam choice for 406??? 66sedanman Engine 13 09-04-2007 09:49 AM
Joe Gibbs camshaft break-in oil additive machine shop tom Engine 2 07-03-2006 06:01 PM
