#1
406 build
Hello All- Im new to this form. So far I've found it very helpful!
Im building a sbc 406. wondering if you could give me some input on which heads to run and about how much HP and torque it will make. Specs below: .030 over (4.155 bore) -cast steel 3.75 crank -SIR I beam rods -full floating pins -Hyperutetic pistons +6cc (sealed power) -pistons are .012 in the hole -hydraulic roller Comp "mutha thumpr" cam (235/249@ .050 .521/.507 lift) -performer RPM intake .030 thich head gasket Debating on the Summit 200cc racing street/strip heads or the AFR 195cc Eliminator street heads. About the same heads except the AFR's are CNC ported and have a heart shaped Combustion chamber. both are 64cc. I know the AFR;s are better but Im on a budget. Would like to try the Summits if you all think they will make about the same power. So really I have 3 questions. 1)which heads 2)about how much HP/TQ 3) approximate Compression ratio Going in a 77 nova-street car, 3.73's and a th350w/ 2500 stall. thanks in advance! Register now (free) or login to remove ads |
#2
IMO I would go with AFR
summit heads are offshore heads im told (thats why they are cheaper) ya get what ya pay for holds true! I got a 406 with Brodix heads and the 400s like to breath so large runners are a must. (I tried oem heads and power was disappointing) |
#5
i did alot of research on sb chevy cylinder heads, and i found that the best deal to be the canfield 200cc. competition products sells these heads for 1130.00 plus a little shipping. these heads came in 2nd place,(1st was afr) in a very large cylinder head comparison database. part number i would get would be 200pk1sp.
| Thread Tools | Search this Thread |
| Similar Threads for: "406 build" | ||||
| still having 406 trouble | tiresmoke55 | Engine | 26 | 11-23-2009 11:58 AM |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| planning the 10 bolt build up | elcaminodragster | Transmission - Rearend | 4 | 11-28-2008 01:04 PM |
| 406 build up,,, need to have more HP | tiresmoke55 | Engine | 34 | 09-01-2006 10:21 PM |
| 406 build opinions wanted | forrest | Engine | 5 | 01-22-2006 12:51 PM |
