406 build....stock crank & rods? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-10-2013, 03:45 PM
vinniekq2's Avatar
give us all the cam specs?
icl/lsa.
maybe tell us about the heads
  #17 (permalink)
Old 06-10-2013, 04:53 PM
hey sorry to jump in yalls conversation but i'm also building a 400 thats gonna put ou only 400-425 hp and i been wondering if i could get by with using a stock oil pump and pan? and are all stock sbc pumps the same...thanks
  #18 (permalink)
Old 06-10-2013, 05:10 PM
Last journal entry: Body
Yes and Yes
The Following User Says Thank You to 38Sedan For This Useful Post:
chevykiid (06-11-2013)
  #19 (permalink)
Old 06-10-2013, 06:20 PM
vinniekq2's Avatar
oil
never hurts to have more oil capacity
The Following User Says Thank You to vinniekq2 For This Useful Post:
  #20 (permalink)
Old 06-10-2013, 08:19 PM
So here are the cam Specs:
ADV dur. 279/281
dur. @ .050 247/249
lift .585/.585
LSA 108
ICL 104
Lash .022/.022
The heads are untouched and setup for this camshaft. I will drop the valves and at least do a bowl blend. I need to read a little more literature before getting crazy with any real port work. It will being going into a 78 camaro with a th 350. I don't have a convertor but will probably go with a hughes 3500 stall, outback it has a detroit locker, 3.90 gears and 26in MT drag radials
  #21 (permalink)
Old 06-10-2013, 08:32 PM
vinniekq2's Avatar
intake lobe centerlineš and lode displacement angleš is also good information
  #22 (permalink)
Old 06-11-2013, 06:44 PM
oil
yea i knew it would but if i was on a budget i was wondering if i coul get by for a while with stock and could i use stock pump and pickup with a 6 qt pan? thanks
  #23 (permalink)
Old 06-11-2013, 06:56 PM
vinniekq2's Avatar
stock oil pump is good for 450 plus hp,6 qts is a good upgrade too.
cheap and high performance doesnt add up to reliability
  #24 (permalink)
Old 06-12-2013, 09:44 AM
oil
but will the 6 qt be any good with a stock pickup
  #25 (permalink)
Old 06-12-2013, 10:15 PM
vinniekq2's Avatar
different pan
what does the pan instructions say?how much deeper is the new pan? How much does a longer pick up cost if required?
dont forget to safety the pick up
  #26 (permalink)
Old 06-14-2013, 02:51 PM
ericnova72's Avatar
More for Less Racer
ADV dur. 279/281
dur. @ .050 247/249
lift .585/.585
LSA 108
ICL 104
Lash .022/.022
Nothing wrong with that cam at all. Car is set-up well for this engine and the larger cam specs just make it that much better in a big 400 small block.
Put it together and you will really like it. Pretty good match for a collection of random parts.
I myself wouldn't worry about internal balancing if this is a street/strip effort not to see over 7200 rpm. Internal balance only seems necessary for the constant high rpm of circle track/road course racing or Drag engines well above 7000 rpm often, in my opinion, but the call/budget is yours.
  #27 (permalink)
Old 06-16-2013, 05:52 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
The external balance engines on the cheaper stroker kits have a history of cracking or braking behind number 2 main journal.The question of balancing or not is as old as the hills.Over time it has been proven no matter what the rpm range is,unbalanced engines are hard on bearings.For the costs involved in balancing vs the risks,it is by far cheaper to balance the engine.
The Following User Says Thank You to 1Gary For This Useful Post:
vinniekq2 (06-16-2013)
Stock Crank/Rods...how much HP too much? Silver Surfer Hotrodding Basics 3 03-05-2012 05:48 PM
5.7 in. rods with stock 400 crank? Warrant Engine 6 11-03-2006 08:37 PM
stock 400 SBC crank in a 383 turned .030 on rods flyin99 Engine 2 04-16-2006 04:56 AM
stock crank and rods nova33 Engine 2 08-21-2003 10:35 PM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 06:03 PM
