Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 cam choices?
Old 11-14-2012, 03:55 AM
LJM97Z LJM97Z is offline
406 cam choices?
Want to hear any feedback on what FT Hyd. or Solid cams some of you are running in a 406 sbc, I'm at 3200 lbs. with me, its a 78 cutlass, I tried a larger Chet Herbert FT Hyd. cam but it had way too much overlap & was rated for 11.5.1 compression, car didn't respond well & it was a bear to tune, I'm either looking at the comp XE line, possibly a Lunati, I'd go Hyd. roller but just can't afford it right now. Hers is the engine combo.
10.4 compression, 205 cranking pressure
Iron Eagle 200cc heads
RPM intake, 750dp
1.5/8 headers
HEI ignition
I have choices of these 2 converters.
10" 2800 stall or 10" 4200
9" with 3.70 gears, 28" tire, but also have 26" ET Streets.
