Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 cam choices?
Old 11-14-2012, 07:34 PM
LJM97Z LJM97Z is offline
Kindof wanting something that'll pull good to around 5600 5800 or so, maybe i need a cam in the 230s on Dur. @50, I have run comp cams XE284Hs before with good results in both SB & BB, but they were Mopars.
I don't know what the deal is on the one 510 cam, It must have alot of overlap, It called for 11.5 compression, so that might explain why it didn't run right.
I just recently installed a 9" with 3.70 gears, i've really noticed a difference over the 4.11s, now my 4200 stall seems a bit much.
