Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 cam choices?
  #29 (permalink)
Old 11-16-2012, 04:13 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Right now you are not trapping with near enough rpm, even for the small 224deg cam ( gear ratio.)
I bet you are barely above 5200rpm thru the traps.
what is the tire diameter? measured effective diameter from the ground to the center of the axle.
You need to get the car to launch much harder (gears, tires rear suspension, converter and get the MPH way up (horsepower/weight ratio) 115 ish MPH for 11sec et's. 6000-6300 rpm shifts, 6600+ rpm trap rpm.
