Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 cam choices?
  #41 (permalink)
Old 11-18-2012, 08:37 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The tires are 275/60/15 MT DRs
Ya I got that, now measure the true loaded radius, on the car, on the ground and re-calc.
(They are effectively shorter then 28")
They are the 200cc & i'm sure there the platinums, good stuff,now just got to get them to do what they should
be doing. Once thing I found critical wiht thee heads and the Sportsman II's the manifold must be port matched to the
head.
SlowMaster mufflers.... you know what to do there.
look at the fuel system too.
engine compression test. valve springs gone away.
