pretty much any camaro header will work we used 1969 camaro headers. the passenger side is a near drop in, requires just a litte work. the drivers side is a pain. we had to cut the headers up and custom fit it. they now make a set to fit this swap but cost $$700-1000.00 , it is worth the money to also get a tubualr cross member , they make them with chevy mounting points, and a flaming river sterring shaft helps. all that was on the seond car we did, the first one we did was a backyard shadetree swap, i forgot which year of manifold we used , prety much any year fits the passenger side, i think it was from a truck with rear exit 2 bolt flange for the drivers side. or if you want to go fast just use a ford motor
