Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 critique my combo please!!!
Old 02-12-2005, 08:45 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
You lobe sep is way too wide at 110*. It should be around 106*
I did not have the flow #s for your heads or intake so i used Brodix 221cc runners and a Super Victor intake. I also put a 1050 cfm carb on it.... but the lobe sep. That's what is holding you back, you have an all out drag cam using a street/strip seperation. Another major point it the compression ratio which i raised to 14.5:1
