406 Engine Build...What do you think? - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 12-15-2012, 12:30 PM
lhmurphy's Avatar
Originally Posted by farmwalker View Post
To find someone who will give you the correct numbers... Or just the numbers you are looking for??
The correct one which happens to be 10.3 and is also the number I was looking for and for the love of god please understand that I meant my friends motor earlier
  #77 (permalink)
Old 12-15-2012, 12:44 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
  #78 (permalink)
Old 12-15-2012, 12:50 PM
lhmurphy's Avatar
Originally Posted by 1Gary View Post
Well when I get it done and in I will try and make a YouTube video and tell u where it's at on YouTube if that suits you?
  #79 (permalink)
Old 12-15-2012, 01:06 PM
1Gary's Avatar
Prove it!!!. Show us the parts you claim you have!!.
  #80 (permalink)
Old 12-15-2012, 01:09 PM
lhmurphy's Avatar
Ok well the kit is on eBay under 406 rotating assembly...unless u want me to make a video of the parts at the machine shop? This is gonna be so funny...type in 406 rotating assembly on eBay and click on the one that says 4.155 bore and -14cc...seller is white performance...
  #81 (permalink)
Old 12-15-2012, 01:42 PM
1Gary's Avatar
Sooooooooooooooo you have a unfinished bare block.Man do you ever need help.
  #82 (permalink)
Old 12-15-2012, 01:43 PM
1Gary's Avatar
Wore me out.Going to go lay down for a nap.
  #83 (permalink)
Old 12-15-2012, 01:58 PM
lhmurphy's Avatar
The block is finished u retard...ready for assembly which will include the 12-600-8 cam and blueprint heads...can't wait to make u look dumber than a bag of hammers
  #84 (permalink)
Old 12-15-2012, 02:40 PM
techinspector1's Avatar
Wiki Edits: 326
OK, after a good night's sleep, I'm not quite as grumpy as I was last night, so let us begin anew.
I googled the 14950-030 you posted and clicked on Skip White's ebay site. The following are some quotes from there.....
"These pistons are for use with 6.00" rods. The compression height is 1.140 -14cc DISH TOP WITH 2 VALVE RELIEFS. 4.155 BORE SIZE, RING GROOVE SIZE, 1/16 1/16 1/8 and will produce approx. 10.5:1 compression ratio on 64cc heads"
OK, so we have that info. Now, a little further down, this is written.....
"These pistons have 2 valve reliefs, and are considered a true REVERSE DOME top -15.2cc."
Hmmm, maybe it depends on who's doing the measuring, I don't know.
"Premium pump gas with an octane of 91-93 puts you on the thin edge of detonation."
Yeah, I'd agree with that. All it would take is a short cam like you plan to use to make 'er rattle.
Now, here Skip is saying 10.5:1, but just for the sake of argument, we'll use your 10.3:1 SCR to figure dynamic compression ratio. Dynamic compression ratio (DCR) takes into account the static compression ratio, the stroke, the rod length and the closing point of the intake valve. Compression cannot begin in the cylinder until the intake valve closes, so that is what determines the cylinder pressure, along with the static compression ratio. After many years of doing this stuff, I have found that the Keith Black calculator works well for me and I will generally use from 8.0:1 up to 8.50:1 dynamic compression ratio for use with pump gas. Some fellows will build a pump gas motor up to 9.0:1 DCR, but I prefer to stay on the conservative side of things. Of course, using a tight squish of 0.035" to 0.045" will go a long ways towards preventing detonation also.
So, anyway, using a 10.3:1 SCR, 6" rod length, 3.750" stroke and an intake closing point of 35.5 degrees ABDC @0.050" tappet lift for the 12-600-8 cam that you want to use, the calculator spits out a 9.05:1 dynamic compression ratio. Now, if we use the 10.5:1 figure that Skip published for these pistons, we would get a 9.22:1 DCR.
My suggestion would be to use more cam with your combination, one with an extended intake closing point to reduce cylinder pressure and the tendency to detonate. Staying with the Thumpr series that you like, the Comp 12-602-8....
12-602-8 - Thumpr
closes the intake valve at 43.5 degrees ABDC and would reduce the DCR to 8.78:1 if you use 10.5:1 in the calculator, or 8.62:1 if you use 10.3:1 in the calculator.
Oh, and by the way, please stop comparing your friend's 350 to your 400. You have an additional 50 cubic inches and that changes the combination. You can't compare apples to oranges.
The Following User Says Thank You to techinspector1 For This Useful Post:
vinniekq2 (12-15-2012)
  #85 (permalink)
Old 12-15-2012, 04:04 PM
lhmurphy's Avatar
Thanks for your advice
  #86 (permalink)
Old 12-15-2012, 04:53 PM
Banned
so we just went from "its running" to "I have a machined block"...
And you wonder why people get pissed.
  #87 (permalink)
Old 12-15-2012, 05:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Why feed this troll, guys? Must be a real slow day... I'm outta here.
  #88 (permalink)
Old 12-15-2012, 05:35 PM
1Gary's Avatar
Sometimes to get the real info is like peeling a onion.Not only does he try to appear as a internet hero who doesn't listen to the advice,he doesn't understand who he is dealing with given the yrs we have had on these forums.
I'm out too.
The Following User Says Thank You to 1Gary For This Useful Post:
lhmurphy (12-16-2012)
  #89 (permalink)
Old 12-15-2012, 06:54 PM
lhmurphy's Avatar
I dunno where u got that? I talk about two engines in my post...one is built and the 406 is being built...sorry of I confused you
  #90 (permalink)
Old 12-15-2012, 06:55 PM
lhmurphy's Avatar
Thanks for being a ******
406 Build crowerjunky Engine 6 01-31-2011 07:42 PM
406 build chevyguy13 Hotrodding Basics 4 04-23-2009 07:09 PM
chevy 406 engine build jak327 Engine 9 02-06-2009 11:11 PM
Help With 406 Engine Build Olds86 Engine 22 09-04-2008 08:02 PM
New 406 build Steve karch Engine 21 12-19-2006 09:30 AM
