I have the dyno sheets but have no idea how to get it to show up on here. I had alot of help selecting the parts for the build from the group at Chevy Talk.
This build was done just for the street. I did have him run it up to 6200 to see how the HR cam would behave and it probably never see the RPM again. I do have some readings for BSFC if that is what your looking for, I can copy them over for you.
Here's what I have, hope it's what your looking for.
RPM Fuel/Gal/Hr BSFC 4000 25.13 .419 4100 26.02 .436 4200 26.71 .434 4300 27.31 .433 4400 27.82 .433 4500 28.45 .435 4600 28.94 .436 4700 29.43 .437 4800 29.80 .438 4900 32.49 .474 5000 37.80 .547 5100 43.10 .617 5200 46.20 .656 5300 47.60 .673 5400 48.20 .678 5500 48.50 .678 5600 48.60 .673 5700 48.70 .670 5800 48.70 .669 5900 48.70 .670 6000 48.70 .674 Now that I've copied these down, could you explain them to me? Thanks |
at 4400 rpm,you are burnig 43 pounds of fuel(7 gallons per hour) for every 100 horse power your engine makes.
at 6,000 rpm you are burning 67 pounds of fuel per 100 horse power your engine makes. much worse at higher rpm I see dyno time could net more horse power and better throttle response,and less fuel burn. sorry I lost the long post,I type slow and my hands hurt |
What else would you recommend?
I took the time to search Ebay to find your kit. I should not have had to do this. I found all the info I needed to calculate your static compression and DCR. The first thing I did was get your parts stack height. 1.875+6.000+1.140=9.015. 9.025-9.015=.010 for piston to deck clearance. Using these figures your static compression is 10.373 and the DCR is 7.951 which runs on 91 octane gas. You asked for opinions on your build but did not have the information to make a logical opinion. The one major difference is the compression height of your piston versus most brands of 400 pistons which is 1.425. You have good parts and it sounds like this is going to be a powerful engine. Post how it runs when you get it in your car. |
Yes, we ran it through 11 pulls. We started with the shop 750 carb and shop ignition. He twicked the engine with his stuff then we switched to mine and we played with different jets and tried different timings. Looked back on some of the earlier pulls and they show more hp and torque but fuel comsumption was higher on the lower end where I would be driving most of the time. There was quite a bit of difference just between the 33 degree setting and the 34 degree setting. At 38 degrees, the chamber temp was too high so he dropped it down to 33 and then up to 34 where he said that it looked like that where I should run it. There was very little difference between the shop Holley 750 and my 770 Street Avenger Holley.
| 406 Build | crowerjunky | Engine | 6 | 01-31-2011 06:42 PM |
| 406 build | chevyguy13 | Hotrodding Basics | 4 | 04-23-2009 06:09 PM |
| chevy 406 engine build | jak327 | Engine | 14 | 02-06-2009 10:11 PM |
| Help With 406 Engine Build | Olds86 | Engine | 39 | 09-04-2008 07:02 PM |
| New 406 build | Steve karch | Engine | 21 | 12-19-2006 08:30 AM |
