Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 engine questions.
Old 11-15-2012, 09:27 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by 95chevy406 View Post
Just bought a fresh 406(so i thought)
Ok the casting numbers says its q 4 bolt but it has 2 bolt caps.is this good?
Also has new h400p cp30 pistons.well it has a small rap(sounds like a wrist pin)
And i saw that they also ground the piston skirts to clear the crank.whats going on with this motor?
As a young man, I used to buy complete motors until I learned that every seller is a liar. Never again. I want it used up and ready for a rebuild or in pieces. Either one is fine, because the cost is commensurate with the value of the hunk(s).
Your noise could be anything, from a skirt hitting a counterweight to a cracked piston to a loose pin to a counterweight hitting the end of the dipstick to one of the rods hitting the cam to................
