406 engine questions.
Just bought a fresh 406(so i thought)
Ok the casting numbers says its q 4 bolt but it has 2 bolt caps.is this good? Also has new h400p cp30 pistons.well it has a small rap(sounds like a wrist pin) And i saw that they also ground the piston skirts to clear the crank.whats going on with this motor? |
Your noise could be anything, from a skirt hitting a counterweight to a cracked piston to a loose pin to a counterweight hitting the end of the dipstick to one of the rods hitting the cam to................
The guy said it ran good with no noises.the pistons only had very litle cabone on them.guessing less then 30 min run time.is it good to use 2 bolt caps on a 4 bolt block.the sound was coming from the # 1 or 2 piston.my cam is only a .435 .465 lift.
Are you saying the block is drilled for 4 bolts but now has 2 bolt caps? If that's the deal the caps won't be registered in the block recesses the way they should be. This would leave them largely unsupported and I would think this would be an invitation to have the caps moving laterally, aka cap walk.
When the 400 blocks were produced, some were manufactured with 2-bolt mains and others were produced with 4-bolt mains. Of course the hot rodders immediately grabbed the 4-bolt blocks because they thought they would be stronger than the 2-bolt blocks. But hold on there, gasoline breath, it was discovered that the webbing in the 4-bolt blocks was not sufficient to prevent pulling the whole shebang out of the crankcase and runnin' over the crank. Oddly, the 2-bolt blocks were stronger and have been used ever since as the block of choice when building a 400. If your block is an original 4-bolt block and has been built using 2-bolt caps, it's still a 4-bolt block with weak webbing above the crank. |
Never took the cqps off to see if it is a 4 bolt but the casting number says it is and yes it has 2 bolt caps.
3951511=70-73 sbc 400 4 bolt main b&g body |
Techinspector1 is right about resellers that are private sellers.There are plenty of honest shops building quality engines like ours that suffer from situations like yours. Those honest shops are nothing without you guys trust.We do really need that.
Just to I.D. what you have or don't have,it sounds like a total teardown.That would be my suggestion. |
Mount the motor on an engine stand. Flip it over to remove the oil pan. Unbolt one of the main bearing caps to see if has 4 holes or two holes under the cap. If it has 4 holes find the guy who sold it to you and get your money back. Tell him you will take him to court if he doesn't want to give the money back.
Got it all torn down.it is a 2 bolt block.stock crank turned .010 on rods and mains.pistons and rods all look good and pins move freely..main bearings have alittle grooving and one rod bearing lock was ground off.the kotor also had low oil pressure at idle after warmed up.less then 5 psi.still not sure what the rapping noise was.
And on all the big ends of the rods there are little cross hairs like they were honed out so i think they were sized.im hoping it was either a bad bearing set or dry start up.
Im gonna have the crank and rods checked.
| Going EFI on 406 SBC questions | LanceM | Engine | 2 | 01-29-2011 11:12 AM |
| 406 sbc questions | brians407sbc | Engine | 3 | 07-15-2010 05:40 PM |
| 406 sbc, build questions | manchildau65 | Engine | 59 | 04-03-2010 06:59 PM |
| 406 rebuild questions... | ddhens | Engine | 4 | 11-10-2007 11:03 PM |
| 406 sbc questions | tiresmoke55 | Engine | 13 | 04-26-2007 10:50 AM |
