Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 help
Thread: 406 help
Old 03-21-2014, 03:51 PM
lumberjack_43 lumberjack_43 is offline
406 help
I picked up 406 short block has a new scat cast crank h6160p 4 vr pistons idealy I would like to hit 500+ foot pounds and not rev past 6000 rpm I'm very new at this so go easy on me my idea is this I mudbog and instead of holding 7500 rpm in a 350ci in first i would like to be able to shift into second and keep pulling (in my little brain this tells me i want torque) I know a set of afr 210 eliminators will get me there but id have to use my rent money for the next 2 months to purchase a set there is also no perfomance shops within 500+ miles of here i can pick up a bare set of motown 220cc, 64cc, 2.08" x 1.60" heads would these get me close? if not is there any other cheaper compitition for the afr 210? I would like to be around 500 hp am i in the range? or am i just blowing out my *** i also need cam help as i dont understand it all correctly yet.
