Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 help
Thread: 406 help
Old 03-21-2014, 07:09 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
If you're willing to run racing gas, then the more compression the better, the 64cc heads will put you in the 11.3-1 range on compression ratio.
The 770 carb will work.
What type of cam do you want to use? Hydraulic flat tappet, solid lifter flat tappet, hydraulic roller, or solid roller??
