406 help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-28-2012, 06:30 PM
gamedawg03's Avatar
Thanks for the info im going to take them to my machine shop and let him flow bench them
  #17 (permalink)
Old 11-28-2012, 06:56 PM
vinniekq2's Avatar
phone the shop before you go,not all or many shops have a flow bench
  #18 (permalink)
Old 11-28-2012, 07:09 PM
gamedawg03's Avatar
Yeah im going to take them to coupe performance out of covington ga
  #19 (permalink)
Old 11-28-2012, 11:06 PM
F-BIRD'88's Avatar
Yada Yada Yada
when building a 400sbc with a 64cc head use a -18cc dished piston.
Like a KB147 piston (5.7" rod length.)
  #20 (permalink)
Old 11-29-2012, 01:21 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Can I ask you about the 400 block??. Are you sure it is a good core??. Those are getting kind of rare. Especially on a 400 you don't want a bore and hone without the pistons in the hands of the machine shop and do not do that without torque plates.A extra step is to sonic check the bores because some are casted as thin wall blocks.You need to know you have a sound bottom end before you spend money on the top haft,don't you??. Don't you need to know you have a flat deck before you plot out heads and SCR's??. Here again the 400's trait isn't to have a used engine with flat decks.
I did see you said a factory 400.but I am not sire what you mean in saying that.Still most of what I posted still applies even if it is a brand new casting.
BTW-have you called Brodix and asked them how much to port good used clean castings??. I would bet money they have a killer porting program that would be hard to match. Even if you have to pay more,you get tons more back in return.
  #21 (permalink)
Old 11-29-2012, 02:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They did a subframe for me a while ago. Did a good job. You run at Head Hunters?
  #22 (permalink)
Old 11-29-2012, 08:14 AM
gamedawg03's Avatar
Yeah i was going to go last sunday i called mandrell he said aslong as its over 50 degrees he would have track open
  #23 (permalink)
Old 11-29-2012, 08:18 AM
gamedawg03's Avatar
Yeah. I sent the block today to machine shop to get checked out it was a complete 45,000 mile motor out of a motor home i bought for scrap a tree had fell on
406 huntg383@yahoo.com Engine 1 08-03-2011 01:48 PM
another 406 badazzbowtie Engine 9 06-23-2010 01:07 AM
1.5 vs 1.6 on a 406 sunman Engine 3 04-21-2008 08:44 PM
406! JCBand Engine 10 05-15-2007 01:08 AM
406! JCBand Engine 3 05-01-2007 07:01 AM
