406 help - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-04-2014, 06:02 PM
Well just from reading online it seemed the .030ish were what was being used. What should i use then?
  #47 (permalink)
Old 04-04-2014, 06:58 PM
ericnova72's Avatar
More for Less Racer
You should try to use a gasket that gets you near the ideal .038-.045" piston-to-head clearance (quench)......but what I am saying is there are not a lot of gasket thickness choices for the bigger 4.125" 400 engine as compared to the 4.000" SBC bore engines. You can't just pull the thickness # out of thin air....You may not be able to get a .027 or .030" thick gasket without having to custom order it. This is the reason decking the block is mentioned so much in build threads here , there are only a few available off the shelf gasket thicknesses so you have to deck to get ideal clearances. .038, .041, .051, .055" I know are available ....you may have to search to see if something thinner is now available for the 400, I haven't looked in a while. Cometic may now have something thinner in an MLS gasket for that bigger bore.
  #48 (permalink)
Old 04-04-2014, 07:21 PM
Proud LOSER
Wouldn't want to hurt one of these and have to redo...
Here's your pn#
http://www.summitracing.com/int/part...make/chevrolet
That being said, Eric is 100% right in his post, I just happened to be in the summit site when I read this so I looked lol.
  #49 (permalink)
Old 04-04-2014, 07:37 PM
vinniekq2's Avatar
lets talk cam profiles,not just pulling degrees duration out of our butts!
Im thinking 10 3/4 to 11:1 CR?with those heads,,,
AFR 220s will make power past 7k in a 400.
we are talking 600 plus hp!
Can you live with a real snotty idle? Power that hits like a sledge hammer?
Or do you prefer a wide power band that is great for road racing?
  #50 (permalink)
Old 04-04-2014, 07:43 PM
ericnova72's Avatar
More for Less Racer
Here's your pn#
Won't work with a 400, no steam holes and is too close to the 4.155" bore size(of an .030" overbore) because you have to allow for the little chamfer at the top of the cylinder bores. 4.180" bore gasket is about as small as you can go on a .030" overbore 400.
4.190" and 4.200" are common gasket bores for the 400
The Following User Says Thank You to ericnova72 For This Useful Post:
bygddy (04-05-2014)
  #51 (permalink)
Old 04-05-2014, 10:38 AM
i want it to be snotty as can be and hit like a sleg at 3000ish rpm
  #52 (permalink)
Old 04-05-2014, 11:03 AM
Was the one i was looking at but yeah no steam holes...
Has anyone blocked the steam holes? if it only starts goes to line races 200 feet then back to the trailer and shut off would i hurt anything by plugging them? besides making me heat faster
I keep forgetting about those darn steam holes on the 400s
  #53 (permalink)
Old 04-05-2014, 11:15 AM
ericnova72's Avatar
More for Less Racer
In your case they can be blocked, they are often plugged for added strength in applications not being run at low rpm (3000 and above most all the time).They plug them using allen set screws...but don't do this on a finish machined block, only plug them before it gets bored and honed as it will distort things when they are installed.
Just allow the gasket to block them off in your case.
That linked gasket still won't work though, it will overhang the piston ring starter chamfer at the top of the bore and become a hot spot...got to be like I said, 4.180" or bigger bore gasket....if you didn't advise the machinist to put the most minimal chamfer back on after boring the cylinders (I'm guessing no to this as you didn't previously know the fact).
  #54 (permalink)
Old 04-05-2014, 11:30 AM
ericnova72's Avatar
More for Less Racer
If you haven't ordered the heads yet, go with a smaller chamber than 75 cc if you are planning race gas or E85 or alcohol.......64cc heads and flat top pistons will get you about 10.9-1 to 11.5-1 compression depending on how much the block has been decked....12.1-1 if you order 60 cc chambers from AFR.
Solid roller cam about 250 to 256 intake dur @ .050 with .600"-.640"ish lift 106 lobe separation.
4000 stall converter minimum.
  #55 (permalink)
Old 04-05-2014, 06:55 PM
vinniekq2's Avatar
re look at the cam I already posted then. Maybe go slightly bigger? and contrary to Eric but not arguing,consider 102 ICL.
note: when that cam hits its peak power,thats all you get,the power rolls off fast
  #56 (permalink)
Old 04-05-2014, 07:01 PM
ericnova72's Avatar
More for Less Racer
I wouldn't have a problem with that...106 lobe separation, 102 intake lobe centerline.
  #57 (permalink)
Old 04-06-2014, 09:58 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
The 400's can use all the help it can get for cooling.
No bore or hone with using torque plates.No bore without sonic checking.Filling haft way up the expansion plugs with block filler helps stabilize the bores.Thin decks and thin wall bores.
  #58 (permalink)
Old 04-07-2014, 01:52 PM
[QUOTE=1Gary;2251178]The 400's can use all the help it can get for cooling.
I had a half filled with Rockblock 406 with the deck plugged. I had cooling problems with it too. I used a Griffen aluminum radiator with a dual fan setup. It always ran 140 degrees, so I put the fans on a thermal switch instead of just on with the key, but it still ran only 160 at best. Finally took out 160* thermostat and put in a 180* and finally it would run at 180* If you fill block though, you need to watch oil temps when extended cruising on the street.
  #59 (permalink)
Old 04-07-2014, 02:08 PM
ericnova72's Avatar
More for Less Racer
I have no problem cooling the 400's I've done either, stock water jackets or half filled with block filler. Good radiator, good stock waterpump from a Air Conditioned car application, and the correct pulley ratio and it is no problem.
The Hot running 400 myth lives on, swap a used 400 in place of a 350 keeping the 350's single row radiator that's 10 years old and partially plugged up and of course it won't stay cool. .......But it's the 400's fault, right LOL
  #60 (permalink)
Old 04-08-2014, 12:19 AM
The 400 in my truck has never had a problem either hottest it ever seen was 210 but that was in a thick nasty hole and it took me 3 and a half mins of WOT to go 200 feet lol
406 macrobert68 Engine 19 02-12-2013 04:57 PM
406 sb emodracer Engine 4 03-02-2011 04:10 PM
406 jeremy1346 Engine 16 10-07-2009 05:28 PM
406 or ? 406chevycaprice Engine 4 01-16-2008 02:31 PM
406 kevyb1973 Engine 3 09-23-2007 02:36 PM
