406 help - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 04-08-2014, 11:33 AM
Cars, Trucks, Boats
Originally Posted by ericnova72 View Post
That linked gasket still won't work though, it will overhang the piston ring starter chamfer at the top of the bore and become a hot spot...got to be like I said, 4.180" or bigger bore gasket....if you didn't advise the machinist to put the most minimal chamfer back on after boring the cylinders (I'm guessing no to this as you didn't previously know the fact).
. Didn't think anyone champfered the tops of the cylinder bores anymore... I don't... just use a good ring compressor to install the pistons... any champfers on the bore or piston tops are places where mixture can hide and not burn... costing power and producing a dirty running, polluting engine... champfers also lower compression ratio...
406 macrobert68 Engine 19 02-12-2013 04:57 PM
406 sb emodracer Engine 4 03-02-2011 04:10 PM
406 jeremy1346 Engine 16 10-07-2009 05:28 PM
406 or ? 406chevycaprice Engine 4 01-16-2008 02:31 PM
406 kevyb1973 Engine 3 09-23-2007 02:36 PM
