406 Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2004, 04:41 PM
MI2600's Avatar
Member# 3287
406 Help Needed
I've got a 406 in my ElCamino that I believe is jinxed. I won't go into the gory details.
Anyway, I've got another 400 block and I bought a balanced rotating assembly with 5.7 rods. The current 406 has the 5.56 rods.
My question is does the block need to be clearanced for the longer rods? The rod bolts are already clearanced for the cam.
Old 06-14-2004, 05:42 PM
BOBCRMAN@aol.com's Avatar
It is really strange, but some blocks need clearancing and others with the same casting numbers don't. It's just Chevy's production and casting variances. Just mock up a short block and check for any tight spots or hits.
Old 06-14-2004, 07:18 PM
MI2600's Avatar
Member# 3287
Thanks Bob.
My thoughts were that if clearancing was needed it would be somewhere around the base of the cylinder...but I may have been wrong once before!
