406 motor with arp sealeant leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2013, 08:34 AM
macrobert68's Avatar
Small Block
I removed each stud 1 at a time cleaned off that arp crap and i mean CRAP!!!!!!!!!!!! The studs had full sealant on the threads when i removed them ,there is no reason for them not to seal except the product dont work !!!!!!!!!!!!!!!!when I told the parts store what i used they all looked at eachother and said another day another person .Yea your not the only one .They all said permatex #2 so thats what i used .I covered the threds installed it ,than removed it added more and waited a few min for it to get tacky then reinstaled to tork 80 ft lbs.Looks good feels good so far
It feels good to get that anger out .
But my Q is i took out the penn break in oil that had water in it .Not that much but i just dont ike the idea of water oil mix .Arter only 4 start ups can i put regular oil in it or should i replace the break in oil ?
Old 02-16-2013, 03:36 PM
Richiehd's Avatar
JS-70
Yeah......where'd the water come from? and if you havent finished your break in (20 min. 2500 rpm) Id put break in back in and start again.
Again, what studs let the water in? Head bolts?
Old 02-16-2013, 04:18 PM
Small Block
The arp head studs most of them leaked .last night and today i tore it apart and changed to permatex#2 just got done ran it for 5 -10 min up to temp and no leaks
350 valve covers leaking and leaking and leaking 85cjsm350 Engine 16 04-17-2016 07:35 PM
sbc 406. Want to build a stroker motor out of it okc87ssmonte Hotrodding Basics 9 07-25-2012 05:58 PM
Soft plug leaking on rebuilt 406 Chevy heathj1 Engine 6 11-10-2011 05:10 PM
Elec. fuel pump leaking into motor??? 0260N2.8 Hotrodding Basics 3 01-12-2009 02:06 PM
How Long will Bare Sealeant last 70chevy Body - Exterior 9 06-17-2004 10:27 PM
