406 oil pan that works with a Z28 windage tray?
I finally got the 406 short block and heads for my '73 Vette back from the shop. The previous owner had a GM 3927136 Z-28 (5 stud) windage tray installed that I want to reuse. I'm replacing the junk chrome stock style oil pan...it's in bad shape and it appears that the studs/tray were hitting the pan baffle and broke all but a couple of the welds holding it in place...lucky it didn't completely break loose...
I'm looking at the GM 360450, but not sure if it will clear. See this post... http://www.hotrodders.com/forum/z-28...ht=406+oil+pan Any recommedations on what oil pan will work with on 406 with the windage tray? Thx... |
360450 is the correct pan for use with that tray. 465220 is also OK, it's just an older part number.
| All times are GMT -6. The time now is 11:09 PM. |
