406 oil pan that works with a Z28 windage tray? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 05:35 AM
I finally got the 406 short block and heads for my '73 Vette back from the shop. The previous owner had a GM 3927136 Z-28 (5 stud) windage tray installed that I want to reuse. I'm replacing the junk chrome stock style oil pan...it's in bad shape and it appears that the studs/tray were hitting the pan baffle and broke all but a couple of the welds holding it in place...lucky it didn't completely break loose...
I'm looking at the GM 360450, but not sure if it will clear. See this post...
Z-28 Windage Tray / Oil Pan Clearance Issues
Any recommedations on what oil pan will work with on 406 with the windage tray? Thx...
Old 08-12-2008, 12:39 AM
360450 is the correct pan for use with that tray. 465220 is also OK, it's just an older part number.
Oil Pan Depth Bull_81073 Engine 3 04-21-2008 05:45 PM
Small Block Chevy Oil Pressure knizet Engine 25 03-21-2008 04:21 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 07:21 PM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 10:44 PM
