406 oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2005, 11:44 AM
406 six speed
406 oil pressure
With a high volume pump...my 406 shows about 12 psi at idle.Idle is about 800 rpm.It shoots up to 40 and beyond when i rev it .The sweep is consistent with the rising rpms.Im just concerned at idle ...should i be?The motor is a hydro roller swap.
Old 08-04-2005, 12:56 PM
Jmark's Avatar
Hmmm, 12 pounds is enough, but I'd think that if the engine is newly built it would have a lot more than that. Did you verify the rod and main bearing clearances when you put it together? If they are on the loose side, your pressure will suffer.
Old 08-04-2005, 01:11 PM
Last journal entry: PICTURE TEST
pressure
what jmark said... Give us your main and rod oil clearances...
Are you by any chance running a fram filter with the by-pass plugged in your filter adapter????
What is your oil pressure at 6000 rpm????
keith
Oil Pressure questions RObs71Nova Engine 22 05-02-2009 02:45 AM
Oil pressure problem blacklotus Engine 7 07-13-2005 01:09 PM
It's alive...finally AngliaBob Engine 5 02-19-2005 01:46 AM
Too Much oil pressure? RObs71Nova Engine 4 11-20-2004 01:52 PM
Low oil pressure at idle on rebuilt 350 Palmtrees57 Engine 25 02-13-2004 11:30 AM
