Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 rebuild questions...
Old 11-11-2007, 12:03 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Originally Posted by ddhens
Thanks for the feedback. I couldn't find any info on the pistons either, but the po definitely says they're flat top. I really hadn't planned on swapping out the heads at this time at $1000-1500, so I'll probably just look at the cam and intake for now. And, if I was going to be doing much highway driving the 3.70s would have to go...but for around town they're ok.
Don;t change the gears. A motor with a cam like that will not be happy with a lower gear. 3.70's are your best gear overall for what you use your car for.
If you want to slow the hwy cruise rpm down a bit go to a taller 28" tire P235-70-15
