406 sbc build need cam advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 08:49 AM
Here is the deal:
I am Building up a 406 - almost completed.
Stock 1969 camaro body and interior,
AFR 195 cc Heads
RPM Air Gap intake
Holley 650 DP will change to 750 in future
Hooker super comp 1 3/4" headers
Dr gas x pipe
Muncie M20 4 spd
3:73 rear
26" tall tire
I am looking for 450 - 500 hp.
It is a street cruiser - want vacuum for power breaks and all accesories. Do not want it to be soggy on the street down low. My engine builder and I discussed camming options (hydrolic roller, Solid Roller, Solid or hydrolic) Although he likes a solid roller he did not think it was necessary to go with a solid roller for my applications but he seemed to lean towards a solid flat tappet.
1) What are your suggestions on the type of came for the street (ie Solid).
2) What duration and lift would you suggest - include LSA
Also, what e.t.s do you think I can make on street tires.
Thanks
TG
Old 05-02-2005, 09:59 AM
Last journal entry: PICTURE TEST
cam
What pistons??
What deck height???
What are the chamber cc's of your heads???
I only ask to get some what of a idea about your static compression....
We need this to make a cam recommendation...
Keith
Old 05-02-2005, 10:08 AM
Compression 10.5:1
Chamber cc's 64cc
Do not know deck height or type of piston - would have to consult with builder on this.
Old 05-02-2005, 10:26 AM
engine
A word of caution here...
If you are running a 64 cc head , with a 10 cc head gasket you will need a piston with a cc volume of 14 cc to get 10.49:1 compression..... So i hope your pistons are of a dished design?????
What is the most important to you????? How fast it is or how well it drives on the street??? Only choose one... L.O.L.
Keith
Old 05-02-2005, 10:42 AM
Both! - LOL
I want it to be streetable where I can run power brakes and all accesories. My last cam was a 230/236 duration on a 110 in a 355. I seemed to like the way that idled. I dont think It want to go more than a 108 lsa. It is a weekend cruiser, I do not want it to be a difficult to drive on the street.
Considering this - I want to get as much out of it as possible.
Old 05-02-2005, 11:05 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Look towards a Comp 282S. It is the best choice for a flat tappet application.
Old 05-02-2005, 11:29 AM
Just to give you a feel, we dynoed a 383 with similar specs that had a CompCam 264HR (hydraulic roller) installed and it made 360 HP, at the rear wheels. That well into the 450 range at the flywheel. Car was an automatic, 700R4.
For a 400 I would consider something along the lines of a CompCam 276HR. That has about 224/230 duration at .050 and .536 lift with 1.6 rockers. AFR heads love lift. If you want to custom grind a cam use about that duration and get them to grind more lift if possible, .550 to .560 would be great. The duration will keep the car very streetable and meet your goals. The Comp cam is just an easy example of the type of grind I think would make you happy. Crane, Howard, Elgin, Lunati can all grind a came similar. I think you'd find it worthwhile to invest in the roller setup.
I agree that you want to stay away from a solid roller unless you are ready to inpect the vlavetrain and lifters every year. It is highly recommended that the rollers be inspected closely for bearing wear.
Old 05-02-2005, 11:38 AM
What about solid flat tappet?
Old 05-02-2005, 12:12 PM
cam
Nothing wrong with a solid flat tappet cam...
how many miles do you drive this car per year?????
Keith
Old 05-02-2005, 12:18 PM
If I put 2.5 - 3,000 miles on it it would be a lot. I never owned a car with a solid in it. Is maintenance a pain in the ***, How often? Are they Noisey? My builder is a big fan of Solids - He seemed to lean that way.
Old 05-02-2005, 12:32 PM
firestone's Avatar
http://teamrfc.gospelcom.net
If you wanted to go solid, I would go with the XS276S (236 242 @.050 .501 .510 lift 110 lsa) with a set of 1.6 rockers. If you have the money, and are going solid anyway, I would recommend a solid roller, you will make more hp. Either way, you will be setting valve lash. I think the XR274R(236 242 @.050 .570 .576 lift 110 lsa) would be a good mech roller. You could go bigger, but I think it may start to have noticeable effects on power accessories. As far as solids go, if you run a stud girdle, you probably wont have to set them that often. I run a car with a solid roller, and they seem to stay in place pretty well. It is hard to say what your car would run on street tires, but I would think that this setup would put you solidly in the 11's with some slicks.
Adam
Old 05-02-2005, 12:44 PM
Solids are maintenance as you'll want to check lash on a regular basis, although the low mileage you will put on might mean twice a year. So no big deal.
BUT, look at your choices based on the head you have purchased. Ask yourself why you spent $1300 on a set of cylinder heads that flow to .600 and why you would not want to match that capability with the camshaft? You wll give up a lot of benefit in the head if you lift it less than .500 lift. As I mentioned before, AFR heads love lift. A hyd roller will lift the valve much faster providing much better performance compared to a solid flat tappet.
It's more money for sure but you'll have no maintenance, better driveablity and better overall power.
Old 05-02-2005, 12:48 PM
Cam
Boy you are going to get all kinds of answers to this deal.......
I personally have not had problems with solid roller cams on street driven engines. If you are sure that you are going to put 3k a year on it i would go with a flat tappet cam tho..... If you have the correct valve train they need very little in the way of maintenance. I have gone a entire summer and never had the valve covers off. Thats 25/35 1/4 mile passes and maybe 1000 street miles....I have customers that run there engines even harded then that with no adjustments......
As for the cam numbers... as a compromise to your needs i would go with a cam that was 240@.050 dur. If my memory serves those heads have a good intake to exhaust ratio for flow and you shouldn't need a split cam for them... I would go with a 110 lsa. That cam installed at 4 degrees advanced will give you a cylinder pressure of about 180 PSI. If you have a 10.5:1 static compression........... That will be good with pump gas.....
Keith
Old 05-02-2005, 12:49 PM
Can I get a Solid cam with a 550 lift with a low 240' in duration?
Old 05-02-2005, 01:00 PM
cam
With out looking in a catalog i cannot tell you for sure but i would not see why not....
Rick wi might be able to give some more info on the lift.... I am new to the cylinder head flow vs real world hp deal but i personally have not seen it make much of a difference in a heavy car... Meaning if you can get a cam with all the numbers and only .525 lift. The same cam with the same numbers and .550 lift will not make much of a difference in 1/4 mile performance in a heavy car..... But once again this is just what i have seen......
Keith
Wanna build a SBC 302. Need Help!!! Super Chevy Hotrodding Basics 9 03-12-2011 08:16 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 09:06 AM
Sbc 406 sb72elcamino350 Engine 9 03-05-2004 12:59 PM
79 CJ 5: SBC or Stock Build Up? mav79 Engine 7 08-20-2003 11:28 PM
