406 sbc, build questions - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-21-2010, 06:34 PM
Some more detail: the noise continues through the RPM range, sound is still present with accessories disconnected (fan, alternator, steering pump, water pump...), pullies have been changed out to another stock set.
The oil pan is a cheapie chrome auto parts version - same with the timing cover. If you were to further troubleshoot, what would your method be? Right now is the ideal time to tear into things... the front clip isn't even bolted in.
  #47 (permalink)
Old 03-21-2010, 06:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would suggest a mechanic's stethoscope or a length of fuel hose held to your ear to isolate exactly where there's metal to metal contact.
Keep your body, cloths, hair , etc. away from the belts and revolving parts. No wristwatch or jewelry, either.
Don't use a long screwdriver for this. It works equally well as a stethoscope- and as a shish kabob stick for your brain.
  #48 (permalink)
Old 03-21-2010, 06:51 PM
Good point with the screw driver
Also, I'll remove all belts to minimize moving parts when listening.
Question:
I put a double roller timing timing gear set in it. Would the cheap timing cover not have enough clearance for this? If it didn't have enough clearance, I'm just not sure why it wouldn't be a consistant sound?
  #49 (permalink)
Old 03-21-2010, 06:59 PM
ericnova72's Avatar
More for Less Racer
Oil pan suggestion is a good one, my brother ran in to this with his 383 and a cheap chrome pan, front pair of rods just barely touched it ot the bottom of its stroke. We didn't find it until is was in the car and running too.
  #50 (permalink)
Old 03-21-2010, 07:21 PM
techinspector1's Avatar
Wiki Edits: 326
Pull the oil dipstick out and run it. Sometimes with the variations of parts that us guys use, the tip of the stick can be hit by a crank counterweight as it comes around.
  #51 (permalink)
Old 03-24-2010, 08:58 AM
Still Noise
I removed the fuel pump and rod, started the engine and the noise was still there. I also pulled the dipstick while it was running and the noise was still present.
With the belts off the front, I started the engine and felt both the timing cover and oil pan and didn't feel anything out of the normal. Someone mentioned that I should make sure that the harmonic dampener is fully seated because it holds the bottom timing gear tight. Is there any way to verify that the dampener is properly seated?
I think my next step is going to be tearing the front back down and looking inside the timing cover. Any additional thoughts?
Thanks
  #52 (permalink)
Old 03-24-2010, 09:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Have you tried using the piece of hose to listen with? This is something used by ALL mechanics, not just something that I dreamed up- you'd be amazed by what you can hear.
  #53 (permalink)
Old 03-24-2010, 09:30 AM
Good point, I was going to try and borrow a friends 'Mechanics Stethoscop' to search around. That would definitely help narrow down the area.
  #54 (permalink)
Old 04-03-2010, 07:59 PM
Problem solved!
I found the noise! Pretty embarrassed about my boneheaded mistake but either way, I'm pumped it wasn't anything major. I used one different cam screw (don't ask me why...) and it was making contact with the timing cover. I went out and bought a set of new screws with a locking plate and bolted it all back up. Everything sounds great!
I appreciate everyone's input and putting up with the multitude of questions
SBC Motor Build weshova Engine 4 10-21-2008 11:10 AM
1980 monte 406 SBC eatonde Engine 8 10-15-2008 08:00 PM
406 build up,,, need to have more HP tiresmoke55 Engine 34 09-01-2006 11:21 PM
383 Build Questions Mustangsaly Engine 3 06-14-2005 10:53 AM
sbc 350 build up questions b/w72 Engine 9 01-08-2004 06:12 PM
