406 sbc, build questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2009, 10:46 AM
Hi, I'm a new member and have some basic questions about a 400 sbc that I'm putting togethor. The following is the information I have about the engine:
Block
Serial Number: 330817
Bore: 0.030" over
Main Caps: 2 Bolt
Crank/Connecting Rods: Stock
Heads
Serial Number: 14014416
Intake: 2.02 SS
Exhaust: 1.60 SS
Rockers:
Push Rods: Stock
Valve Springs: Doubled? (one inside of another)
Valve Guides
Tapped/Studded Rocker studs
Combustion Chamber: I was told 64cc but the 416 head is 58cc right?
Camshaft
SUM-1107
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 3,000-6,500
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 302
Advertised Duration: 292 int./302 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift
Lobe Separation (degrees): 114
Pistons
Ring dimensions 5/64, 5/64, 3/16
Dome shape: .135 dish; 4 valve reliefs
Compression dist 1.560
Deck Clearance .025
Skirt Clearance .0015
So, I'm sorry to data dump but this is the engine I recently purchased as is. The application will be for a pickup I'm building (K30) and will be using it for fun mostly, definitely want to run pump fuel in it. I've had it running previously with 93 octane and it was very strong with great oil pressure.
First question: is this set up any good? or what should be changed?
Second question: I need a head gasket, what gasket should I get?
Third question: what kind of numbers can I expect from it?
Thanks guys for any input, I'm a novice, with very limited money (recently married) and just want something fun and reliable.
-Luke
Old 04-04-2009, 11:48 AM
Carburetor
I also do not have a carburetor... I take that back, I have a Holley 600 or 650 (don't know the part number off hand) but it was given to me and needs parts/gaskets and I think it is too small. Any suggestions for a budget carb?
Old 04-04-2009, 11:51 AM
dawg's Avatar
NAVY VETERAN
get a felpro head gasket with steamholes for sure
you set up seems pretty good but vacum might be borderline
im betting 430hp guess.
Old 04-04-2009, 01:09 PM
Banned
Those heads can't support 400hp UNLESS you take the time to port them out- then they're pretty decent. That cam looks little big for your intended use, but it will run fine, just not have as much low end as I would prefer.
My only suggestion is to port the heads. I don't believe 305ho heads had steam holes so you wouldn't need a gasket for them unless you had them drilled- which would also be a smart move.
Summit has a budget line of carbs that came out recently- I believe they have a 750 for like $250, it would be plenty for that.
LASTLY, measure your piston dish volume, your chamber volume, and set your quench distance to about .040"- you can use that to figure your compression. No more than 10:1- preferabley around 9.5:1 for a daily driven truck.
Old 04-04-2009, 11:38 PM
Boring the Steam Holes
What's involved with boring the steam holes into the 416 head? Is it easy enough I can do it in my garage or do i need to send them to a machine shop?
Also, I failed to mention I have roller tip Crane rocker arms with different ratios for the exhaust and intake valves... don't remember what they are but will post up tomorrow when I check.
What's involved with Porting them? again, can I do this myself or is this something i need to have a shop do?
Thanks again for the replies and I appreciate any input!
-Luke
Old 04-04-2009, 11:58 PM
BackYardRacer
its not hard to put the steam holes in them just line a head gasket up and drill
take you time to line every thing up i've done it a few time havent had any problems with them. now porting your head is a nother thing that alot harder to do get a good grinder alot of books and some one that has been doing it for years all in the same room you could give it a shot but start with a junk set because you will mess the first piar up
and they need the steam holes or it will over heat hard on head gaskets
Old 04-05-2009, 12:02 AM
Steam Holes
Nothing more besides lining up the gasket and drilling? How deep? at what angle? what size? I guess I'm nervous, these heads have had a lot of work done to them (probably too much for a simple 416 head) so I'm a little scared with just drilling some holes... Anyone have pictures?
Old 04-05-2009, 12:03 AM
techinspector1's Avatar
Wiki Edits: 326
http://www.gregsengine.com/350to400.htm
Old 04-05-2009, 12:07 AM
BackYardRacer
drill the hole strate the hole should be the same size as what in the block not hard to do
Old 04-05-2009, 05:21 AM
Thanks!
The attached tech article is extremely informative! The only detail missing is the depth of the holes... do I just drill until I've cleared through to the water chamber?
OK, another newbie question, I've never ported a set of heads. Can you guide me to another tech article on the right procedure?
With the engine torn down, would I be better off in the long run to suck up the 80 bucks or so and buy another hydraulic cam? or do you think the one I have will produce some good power with my set up?
Thanks again - joining this site has proven to be invaluable!
-Luke
Old 04-05-2009, 07:46 AM
Carb and Intake
The engine currently has an Edelbrock Performer RPM, since I need a carb with atleast ~710 cfm I'm looking at staying with Edelbrock and buying the 1407 750cfm unit. Any opinions? I've had good luck with Edelbrock in the past, they seem to be the easiest to set up and maintain... to a novice.
Thanks again for any input.
Old 04-05-2009, 07:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes.
Old 05-10-2009, 05:47 PM
So it's time to button the engine back up, and I've a couple questions prior finishing everything.
1) I thought that chromoly rings were a great idea when I first started this build years ago, however, even now as I'm in the process of refreshing the engine the oringinal cross-hatching is still present. Should I tear it further down and replace the Chromoly rings with a standard set? This engine will be a toy, meaning I won't be putting many miles on it but will be running it hard.
2) I need a set of head gaskets, in my opinion I have too high of compression so I'm looking to reduce the ratio if in any way I can. What do you think of these head gaskets for my application: SUM-111505 ?
As always, I appreciate any and all feedback.
Old 05-12-2009, 11:44 AM
Any thoughts or questions guys? I really don't want to tear into this engine again in the near future.
Old 05-12-2009, 12:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are the rings already broken in to the cylinders? If yes, I'd leave it as-is if they're low-milage.
BTW, the rings are either chrome or moly. While there are steel rings, they're usually not found in a street-type build.
Which type it is (Cr or moly), is important as to how they'll break in and what type of bore finish is required for them.
If you have not honed the block, and the rings are new chrome-faced rings- they'll never break in, or will take for-freakin'-ever to do so, IMO.
If they're moly rings, there's at least a chance they'll break in on an unhoned bore- but to try might well have you tearing the whole thing back down if they don't seat. Not worth the risk, IMHO.
I don't know what those gaskets are (just a friendly FYI: Providing a link would help. Most folks don't want to have to look up part numbers)- but you want to balance the piston-to-head distance (you hear this called both quench and squish, depending on who you're talking to) with the CR- too much of either isn't good.
You might get away w/as much as .060" "squench", but many people will say (rightly so, in many cases) this is too much; 0.040" is the target for a SBC in most cases.
But things being as they are, this is about all the options as to lowering CR and keeping squench within reason. With it at the max, you about have to live w/whatever CR that gives you, unless you want to machine the pistons, or change them altogether.
Good luck!
SBC Motor Build weshova Engine 4 10-21-2008 10:10 AM
1980 monte 406 SBC eatonde Engine 8 10-15-2008 07:00 PM
406 build up,,, need to have more HP tiresmoke55 Engine 34 09-01-2006 10:21 PM
383 Build Questions Mustangsaly Engine 3 06-14-2005 09:53 AM
sbc 350 build up questions b/w72 Engine 9 01-08-2004 05:12 PM
