406 sbc carb selection PLEASE HELP!!!!
Hello everyone I'm a long time lurker here, this site is like a encyclopedia of hot rods. I'm building a 550hp 406, afr 210, 560 lift,240 duration behind a t56 and 410 gears. It's going into a 92 firebird, my dilemma is carb selection, I'm following a build on the afr website, shows 750dp, but when I called the original builders they recommended a hp950. I did research on hp 950 and found out they aren't exactly 950 so I'm at a lost. Can anyone help 750? Hp950? Dominator? Thanks in advance!!!
Anyone? Any help?
Try this? http://www.gtsparkplugs.com/CarbCFMCalc.html If you input 406 cu in, 7000 max RPM, and a VE of .90, you get 907 CFM. |
That said, it will work fine on your engine once it's dialed in. FWIW, BG carbs often didn't flow in cfm the numbers that were associated w/a particular carb, either. In at least some cases they went by the throttle bore and venturi diameter, really had nada to do w/actual flow. There was a thread that Tech @ BG and I 'discussed' this at some length but I can't seem to locate it just now... |
The holly 830 hp will work great on your engine. |
Thanks everyone the t56 will be upgraded to viper specs to handle the hp.
I do believe I've stumbled upon that post with the bg tech So by 830 you mean the "950"? I only have one shot at the carb want to make sure I get the right one. Thank you for your help again! |
For a 4 stroke engine:
CIDxRPMxVE/2456=CFM Divide by 2456 to account for 2 revolutions of engine for one intake of air/fuel, and dividing by 1728 to convert cubic inches to cubic feet. As for the carb numbers actual flow, I know there are lots of factors, I always assumed they were rated at STP. Perhaps a carb engineer could explain. |
Love my Holley HP series 830 carb!!!!!!!!!!!!!
X2 I'm running the Holley HP series 830 on my 400/408 and it works just fine. Cole
Im looking into the 830 right now, found a demon 850 for a good deal? Any advice?
Anyone?????
750 is allllll you need.
Im running a 750 mighty Demon on mine they flow 830 just right and your combo is similar to mine! ![]() By profleetline at 2011-04-16 |
What are you running?
scat crank and rods internally balance lunati solid roller 243/249 @.050 595 1.5 harland sharps comp rev kit 210 profiler heads from chad speiers 2.08-1.60's hurricane intake also ported by chad 1" hvh carb spacer msd billet dist. With 6al melling select pump 7 quart pan cloyes billet roller chain rossler t 400 3,800 neal chance narowed 9" 4.56 with a 4 link |
carb size
If your 950 Holley is a 3 barrel, then stay away from it. 950 cfm is the correct size for your engine, as long as it is a 4 barrel. A smaller carb (830 or 850) will run great and have more torque at lower rpms, but run out of power over 6,000 rpm. Bottom line: If this is a drag car go for the larger carb (950 cfm) since you won't be spending much time at lower rpms. If this is mainly a street machine, go with the 850 cfm carb since most of the time you will be under 6,000 rpm.
| carb selection. | 7fastelc0 | Engine | 11 | 06-28-2011 12:13 PM |
| carb selection | david ahluwalia | Engine | 4 | 03-03-2009 05:33 AM |
| Carb selection for 427 sbc | MadmanMark | Engine | 8 | 12-20-2007 05:57 PM |
| Carb selection help | SLR_65 | Engine | 2 | 09-03-2007 05:44 PM |
| Carb Selection | 1974 gto | Engine | 17 | 01-10-2006 11:51 PM |
