Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 sbc Carb size??
Old 08-18-2012, 08:44 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
when I used 2 x 4 bbl on my street car, I used 2 x 750s. For some reason people think that you divide 1 four bbl in 1/2 and use 2 small 4 bbls,not true.You would use 2 carbs the same as if you used 1 carb on a single carb manifold( approximately) Tunnel rams come with different plenum sizes same as single plane intakes. If you buy a "cheap" tunnel ram,expect the same performance as buying a cheap single four BBl with an extra carb to add to the confusion.
